Results 1 to 2 of 2
Thread: Varying water pressure
    DIY Retired Member walt_pittsburgh's Avatar
    Oct 2010
    Pittsburgh, PA
    Default Varying water pressure
    I find that every few months I have to adjust the main pressure valve in our house to bring up the water pressure. I try to keep it between 50 and 60psi. This is fine for my wife and me. It is just 2 of us in the house. Every few months I will notice a loss of pressure. A test will reveal it is down around 40psi and below.
    We have a newer home that is at the end of the water supply line in the street. Can I expect the pressure in our home to vary if the pressure from the public water source varies? I have gotten different opinions on this. I don't know how the pressure in our home would not drop if the PWS pressure does. I don't know if I need to install a new valve or expect these fluctations due to the public water source.
    IF you can raise the pressure by adjusting the valve, then the valve is defective. It should ALWAYS have the same outlet pressure, regardless of the city's pressure, as long as the incoming pressure is higher than its setting.
  1. Tankless with varying incoming pressure from well tank/pump?
    By rick.a in forum Tankless Water Heater Forum
    Last Post: 06-16-2011, 06:08 PM
  2. Water Softener On = No Pressure, Bypass = Normal Pressure?
    By jsarin1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-08-2011, 04:06 PM
  3. Changing water pressure on house pressure regulator.
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 09:20 AM
  4. High Water Pressure Spikes on Well with Pressure Tanks
    By RayMan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2010, 12:57 AM
  5. Water in well, pump working, can't build up pressure, but doesn't lose pressure????
    By bgnotaplumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2007, 10:32 AM
