Results 1 to 2 of 2
Thread: sub pump install
    DIY Junior Member Tomcat0316's Avatar
    Aug 2011
    new york city
    Default sub pump install
    also im open to suggestions on how to connect 3 sub pump lines. I was planning to install 3 sub pumps and use 2" pvc to discharge the rain water. i wanted to come up along the wall the with the pipes and connect all 3 pipes, then drill a hole through the wall and run the pvc pipe the length of my yard into the woods. i was told to install a safety valve on each line closer to the sub pumps to prevent back up of water......
    Feb 2011
    NW Ontario, Canada
    I would not tie the drains together. I would take them up above ground and drop the pipes down into a single 4" or two 3" underground drains and maintain an air gap at the junction. If you put checkvalves inline, you need to be concerned about the lines freezing.
  1. Guidance re: selecting pump for new well install
    By chrismid in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-24-2010, 06:27 AM
  2. Help w/New Deep Well Pump Install
    By NGSP2008 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-28-2008, 07:18 AM
  3. New Sump Pump Install
    By nesquick97 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-18-2008, 06:45 PM
  4. ejector pump install
    By jwray in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-18-2005, 08:25 PM
  5. Sewerage pump install
    By Agewon in forum Remodel Forum & Blog
    Last Post: 01-19-2005, 07:23 PM
