Results 1 to 8 of 8
Thread: What size for pH neutralizer?
    DIY Junior Member Shooter45's Avatar
    Mar 2011
    MS
    Default What size for pH neutralizer?
    Can someone help choose which size ph neutralizer I need for our new home with water well? Having a hard time deciding between the 1.5 or 2.0 cu.ft.
    House is 3 bathroom and 4 people. 2 of which are teenage girls who love long showers.
    I tested the well and it produced 5 gal. in 24 seconds which I calculated to be roughly 12.5 gpm? I also ran this "Flow Rate Test for Wells" - http://www.cleanwaterstore.com/techn...flow_rate.html and came up with 8.81 gpm
    ph is - 6.5
    Which would be a good size for us?
    Dec 2009
    Alaska
    If you have the flow rate then the 2.0 would be a good choice.
    Is there any thing else in the water like iron?
    Which control or valve where you looking to have on the unit?
    Mar 2011
    MS
    Quote Originally Posted by Akpsdvan View Post
    Haven't had it tested for iron but I do believe there is some because we do get a thin reddish orange film in toilet bowls.
    Would like the 5600 for the simplicity but have been told that 2.0 works best with the 7000.
    Looking at the flow I posted do you think it is enough for the 2.0?
    Dec 2009
    Alaska
    2 cubic calcite would need 7gpm for its back washing.
    The 2510 from fleck would be a better choice over the 7000 valve.
    The 7000 is good but is more for higher flow rates.
    The 5600 has no way of changing any of the parts of the backwash and rinse, while the 2510 the pins can be added to add time to the backwash and spaces added for a slow rinse and pins added for the rapid rinse.
    The 7000 is all digital in its control and more expense if that control goes bad, the 2510 has 2 motors one for the piston and then one for the timer control.. the piston motor is very likely never to go bad while the timer motor could go out it is in the 40.00 range.. digital control for the 7000 would in the 200.00 range.
    Mar 2011
    MS
    would I have a problem running the 1.5 with my flow rate?
    Dec 2009
    Alaska
    The 1.5 runs lower back wash rate and a lower service flow rate and it might not be enough time for the water to be corrected to above 7.0..
    Mar 2011
    MS
    Thanks. I'll try and find a 2.0 with the 2510 head.
    Dec 2009
    Alaska
    This is just one site..
    http://www.ohiopurewater.com/shop/cu...cat=212&page=1
    There should be others.
    I would rather have smallest gravel and not garnet, but that is just me.
  1. acid neutralizer
    By devans175 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-19-2010, 08:05 AM
  2. problem with ph neutralizer
    By tfasbind in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-05-2010, 05:34 PM
  3. Neutralizer backwash HELP.
    By 1krzqb in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-27-2009, 07:16 AM
  4. PH Neutralizer
    By Dan_Cef in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-22-2009, 09:51 PM
  5. Neutralizer questions
    By npurdy506 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-20-2008, 01:17 PM
