Results 1 to 9 of 9
Thread: Leaking thread on softener
    DIY Junior Member Virtualdodo's Avatar
    Aug 2011
    Alberta
    Default Leaking thread on softener
    Just installed a new whirlpool water softener everything went OK for th most part all my connections worked great, no leaks but the problem happens at the softener, I have 3/4" PEX going to the softener which is a 1" male NPt connection, so to preform this conversion i used a 3/4 x 1" sharkbite this connect my 3/4. PEX to a 1" Copper female threaded connection, put some Teflon on the plastic NPt connection threaded the Copper and I am getting dripping from my IN I have taken it off put on more Teflon put on less tightened it hand tight and wrench tight, nothing works just using Teflon tape on a blue roll if that means anything, my out is leaking to but almost not even noticeable like 1 drip every few min so not sure.
    Any thoughts I am at my wits end here, I am hoping these Copper fittings aren't messed as they cost almost 30 bucks here.
    I wanted a 3/4 PEX to NPt Male then just use a hose to connect which is what whirlpool shows on their site but the local hardware store looked at me like I had a horn growing out of my head.
    Sorry for any grammar and spelling on my phone.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    With copper, you can tighten it to the 1" threaded connector until you cannot turn it anymore. In other words, thighten the shit out of it.
    Aug 2011
    Alberta
    Quote Originally Posted by mialynette2003 View Post
    With copper, you can tighten it to the 1" threaded connector until you cannot turn it anymore. In other words, tighten the shit out of it.
    Tried that tightened it right to the bottom of the threads still dripped.
    Nov 2010
    Ocala, Florida
    I use teflon tape and pipe dope on my connections. May want to try that.
    Aug 2011
    Alberta
    So pipe dope first then wrap it in Teflon? I heard not all Teflon is created equally is this true? If so what's the beat stuff? What's the best dope? I hear some only do certain things.
    Nov 2010
    Ocala, Florida
    Teflon tape first, then pipe dope. Some teflon has a lot of air whipped in to it. Not sure what brand name to buy, I've just always used both and don't get the leaks like you are.
    Aug 2011
    Alberta
    Teflon tape first, then pipe dope. Some Teflon has a lot of air whipped in to it. Not sure what brand name to buy, I've just always used both and don't get the leaks like you are.
    I have read lots of stuff on the net to not use pipe dope on plastic as it could break it down especially when water is involved.
    Some pipe dope cans have oil that can soften the plastic.
    Some cans will say if they are okay or not.
    Aug 2011
    Alberta
    I called whirlpool and as soon as i said the problem the guy knew the answer he said put Reactorseal #5 on that should fix it he said the copper and plastic will chew through the Teflon tape like butter, Does that sound about right to you guys?
  1. Replies: 9
    Last Post: 03-26-2011, 06:19 AM
  2. leaking TPR- changed still leaking
    By dough41 in forum Boiler Forum
    Last Post: 02-03-2009, 06:04 AM
  3. Leaking......?
    By Mid Night Illusions in forum Shower & bathtub Forum & Blog
    Last Post: 03-10-2008, 08:14 AM
  4. Leaking tub tap.
    By meggie in forum Shower & bathtub Forum & Blog
    Last Post: 03-07-2008, 05:56 AM
  5. Leaking tap
    By crage1927 in forum Shower & bathtub Forum & Blog
    Last Post: 02-06-2008, 01:59 AM
