Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
Thread: Big basement bathroom project
    Default Big basement bathroom project
    I have a narrow basement. The bathroom currently sits square in the middle wasting space for what could be a very usable room. Meanwhile, I have wasted space at the other end of the basement where I want to put the bathroom instead (where the washer and dryer are).
    I have included two rough diagrams (not to scale)
    The existing 3" flloor/vent stack/sewer line are shown. A 2" vent will cross the ceiling for 10' and then turn and travel 8' to the existing 3" vent stack. It will be attached to the vent stack above the highest drain connection.
    For the vent stacks servicing the new bathroom, do I need to put a third for the toilet or will the two branches serving the sink and tub be sufficient?
    The existing sewer line is 2 1/2' below the foundation. The new run will drop 4" over the 16' run. It won't connect to the floor drain as it appears in the rough diagram. That drain is actually offset from the sewer line.
    My big concern is the 90 deg in the sewer for the new bathroom. Is this acceptable? Is there a better solution to turn that corner?
    Plumber Cass's Avatar
    As far as the 90 goes bust up more of the floor and use 2 - 45s with at least 2' of pipe between them. When you say "The existing sewer line is 2 1/2' below the foundation." do you mean the floor or the footer can you be more specific?
    Default pipes
    A plumber would simplify the layout by using a long radius elbow at the turn and also below the toilet connection, then he would use a 3x2 side inlet tee for the toilet and bathtub/shower with the 2" going to the P trap. Then the lavatory/sink would connect to a T in the toilet's 2" vent line and then the single vent would connect back to the 3" above all the other connections, which means it would be at least 42" above the floor in the first floor wall. You would also need a 3" cleanout in the pipe above the floor behind the toilet.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    You will save about 4 ft of breaking concrete if you run the sewer line diagonally.
    Cass,
    I was planning on using two 45's to soften that elbow. i wish I could go diagonaly but that would require moving the furnace. The sewer pipe is 2 1/2' below the top of the floor.
    HJ,
    I gather from your description that something like what is in the attached image will be ok?
    Or, would this be acceptable? This would be easiest because it' will be difficult to get the new 2" vent line coming out of the floor close to the wall. I'd be able to hide it more effectively behind the tub installation.
    I hope you mean 2 1/2" from the bottom of the floor because most floors are 4" thick. Even still unless I'm not getting something right where you make your tie in the existing line will be higher than where the run ends. Am I not understanding you right? If I do get you right you will need an ejection pump and pit.
    The sewer drain is approximately 2 1/2' (feet) below the top of the floor where it exits the house and that is where I will be tieing in.
    is the vent pipe diagram I last posted acceptable?
    Lastly, when I repour the cement I don't want the slab settling. Can I drill pilot holes in my cut edges and insert some short rebar (spelling?) to support the new cement?
    I'm still in demo mode right now. I have most of the trenches cut in the foundation and have broken up the cement and carted it away. I'll be posting pictures of my bathroom project as I progress. Home demo is always tough because I have to account for the WAF (wife acceptance factor)!
    I do truly appreciate all of your advice!
    Thumbs up
    OK found an answer to my rebar question and pilot holes for rebar dowels.
    Quote Originally Posted by fiasco
    Its going to have to be "close to the wall" somewhere, why would it be difficult behind the toilet? That drawing makes the lavatory arm too long. I don't want to take the time to do a new drawing, but if I were doing it, the tee would be in the floor under the new wall behind the toilet, and the tub would go into the side of it with the toilet's closet bend into the 3" opening. Then the vent would go vertical with the tee for the lavatory at the proper height, then a 3" cleanout about 36" above the floor with a 2" bushing in the top of it. There are a few of "good" ways to install your layout, and hundreds of "bad" ways that look easier. Your job is to separate them and pick the best one for you.
    HJ,
    Again, I really appreciate the input. I am still in demo mode, got to move the washer dryer, water softener and water heater so I can get to the existing sewer run.
    I just installed Visio so I will post some actual plans instead of stick drawings probably later tonight.
    Rebar dowels are probably a bit overkill for a basement floor. Compact the dirt well when back filling.
    When we use rebar dowels in larger commercial applications, we epoxy one end in the existing slab and grease the other so it does not adhere.
    Paul
    Plumber/Gasfitter dubldare's Avatar
    Sep 2005
    MN/ND
    Here's how I'd do it.
    Here is the floorplan layout. I'll post plumbing diagrams later tonight.
    Is there a specific "schedule" PVC pipe that must be used for DWV?
