Results 1 to 3 of 3
Thread: bathroom light/fan combo
    DIY Junior Member ElectricalNewb's Avatar
    Aug 2011
    Ap-po-mat-tox Virginia
    Default bathroom light/fan combo
    i have a light fan combo that i'm using to replace a standard light in my bathroom since i have a major moisture problem and the house was built in the 50s. i have my black and white (hot and common) wires coming from the breaker and going directly to the light. I have new 12/3 wire running to the switch from where the light is. i need to know where to send my power from the breaker thru the switch and make it function properly.
    Are you adding a new switch so you can control both of them separately?
    The hot lead would get attached to the white from the 12/3, that white would get jumpered to one terminal of each switch (assuming you are going to use a separate switch for both the fan and light). Then use the black on the other terminal of one switch and the red on the terminal of the other. Back at the fan/light, connect the black to the one where you want the switch with the black on it to control, and the red to the other. You should put some black tape on the white lead at both ends to identify it as being hot.
    Basically, you need to jumper the hot wire to the switch(es), and then through the switch(es) back to the things you want to control.
    Jun 2009
    Canada
    Why would you be using 12/3?
  1. Bathroom question, fan/light combo above the tub
    By TrevorO in forum Electrical Forum discussion & Blog
    Last Post: 09-19-2010, 10:00 AM
  2. Wire question on bathroom fan/light combo
    By gmaninca in forum Electrical Forum discussion & Blog
    Last Post: 05-17-2009, 01:20 PM
  3. bathroom light heater fan combo
    By Gfro in forum Remodel Forum & Blog
    Last Post: 05-16-2009, 09:19 AM
  4. Combo fan/light above shower & GFCI
    By diymak in forum Electrical Forum discussion & Blog
    Last Post: 01-11-2009, 04:17 PM
  5. bathroom vent/heat lamp combo
    By rioguia in forum Electrical Forum discussion & Blog
    Last Post: 01-27-2008, 02:04 PM
