Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: 1 1/2 hp Sta Rite well pump pressure switch
  1. #16
    Feb 2011
    NW Ontario, Canada
    You'll need to get an electrician to see if 230 volts is available in the shed and if so wire in a 230 volt circuit with a double pole disconnect so that you can run the pump on 230. Also verify that the pump is actually set to 230 volts.
  2. #17
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by RJB View Post
    have 40' from pole to shed and 50' from shed to pump. 12 gauge.
    First you said it was 30 feet from shed to pump, now it's 50 feet plus another 40 feet from the pole for a total of 90 feet. Is that a single 12/2 feed from the pole to the shed as well? How much more wire between the service entrance and the pole or is the pole central metering? Is there 230 volts available at the pole?
  1. Low pressure, pump stays on - tank, pressure switch? Replace all?
    By applebach in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2011, 04:51 AM
  2. I think pressure switch is not receiving pressure from pump.
    By jeremytl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-04-2011, 06:26 AM
  3. 2 Houses, 2 Pressure Tanks, 1 pump, 1 controller, 1 pressure switch pro help needed!
    By betaman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-05-2008, 05:07 AM
  4. Sta-rite lawn pump
    By jimbo11 in forum Irrigation / Sprinkler Forum
    Last Post: 03-26-2007, 05:28 AM
  5. ***Help***Pressure tank/pressure switch/pump
    By s4orce in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-28-2007, 02:11 PM
