Results 1 to 3 of 3
Thread: water flow
    DIY Junior Member Deloras White's Avatar
    Aug 2011
    florida
    Default water flow
    can you help? There is a constant flow of water coming out of the drain hose and you can hear a humming sound .
    Dec 2009
    Alaska
    What kind of system are we talking about?
    Could be that one of the seals or the piston needs to be replaced.
    Could also be that the system has stopped in a spot other than the service spot..
    More information is needed to help in figuring out why it is doing what you are talking about.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Most units have a bypass so you can stop the water flow.
  1. How to increase low flow toilets water flow
    By Lisa J. in forum Toilet Forum discussions
    Last Post: 07-26-2011, 01:31 PM
  2. Shower head flow restrictor blocks all flow??
    By K. in forum Shower & bathtub Forum & Blog
    Last Post: 09-07-2010, 09:25 PM
  3. Bladder to feed a cold water line that has low flow on city water.
    By FBXFixIt in forum Plumbing Forum Discussion & Blog
    Last Post: 09-17-2009, 09:58 AM
  4. little flow of water
    By picapiedra in forum Plumbing Forum Discussion & Blog
    Last Post: 06-20-2009, 01:53 PM
  5. Flow rate? Flow thru? Water softner restrictions.
    By polocash in forum Plumbing Forum Discussion & Blog
    Last Post: 03-29-2005, 10:16 PM
