Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: repair pvc supply line immediately after pvb?
  1. #16
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    How bout this?Name:  imagesCAKN9CDB.jpg
    You should support the PVB though, it shouldn't be supported by the pvc.
  2. #17
    DIY Junior Member GSK's Avatar
    Aug 2011
    MI
    Right, that's the piece I meant. I guess I just couldn't find it at lowe's.
  3. #18
    Aug 2011
    MI
    Fixed!
    Name:  fixed sprinkler line #1.jpg
Size:  64.2 KBName:  fixed sprinkler line #2.jpg
    As I was connecting the last piece I realized that I probably should have replaced the other ball valve too.
    This afternoon, I checked it and saw a very slow, tiny drip, more of a slow ooze, at the connection between the outlet ball valve and the PVB. It's slow enough that I haven't noticed my water meter move yet, so I'm not going to worry about it for the rest of this season. What are my options- removing the PVB to tighten the joint, or cutting out the PVC again?
  4. #19
    irrigation tech. mike1059's Avatar
    Jun 2011
    Portland, OR
    If you have enough room between the pvc and the wall cut the pvc 1" below the elbow, tighten the ball valve one turn then install a coupler below the elbow.
  1. PVC repair irrigation water supply line from the street
    By themp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-28-2011, 05:58 PM
  2. Repair short stubbed supply valve
    By deethib in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-13-2009, 10:06 PM
  3. Sprinklers come on then immediately turn off
    By lonestar54 in forum Irrigation / Sprinkler Forum
    Last Post: 06-20-2008, 03:55 AM
  4. DIY Sewer Line Repair
    By TrailRunner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-21-2006, 06:44 PM
  5. Under slab sewer line repair
    By Slabhome in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-23-2004, 09:32 AM
