Results 1 to 5 of 5
Thread: Well-X-Trol WX-102 Pressure tank issue!?? Need confirmation
    DIY Junior Member Bassett72's Avatar
    Aug 2011
    WI
    Question Well-X-Trol WX-102 Pressure tank issue!?? Need confirmation
    From everything I have read, I think my 8 year old tank is shot. I believe there is a leak in the bladder, but I want to run it by you folks to confirm my suspicions. I appreciate any input/advice you can provide. Thanks, and now on to the story...
    For the last 3 weeks we have been seeing very noticeable surges in our water pressure. Going very low, not quite stopping, but then surging back up. It happens everywhere; the shower, flushing a toilet, running the bathroom faucet.
    So, I finally had some time to do some research on what might be the issue. From that, I turned off the pump, drained the pressure tank, and checked the pressure on the tank. The factory setting is 18 PSI. I had 53 PSI. I thought that was a bit odd, so I shook (as much as possible with an in-line tank) and heard water sloshing around. I then pressed the pin on the schrader valve and a little water sprayed out along with the air. All this leads me to believe that the bladder has a leak in it.
    Is that correct?
    IF that is the case, it appears replacing the tank is as easy as unscrewing it and installing the new one. Is that a correct assumption? I'm fairly handy with a wrench, but I will admit I have no expertise in well systems.
    Thanks again for your help...
    Feb 2011
    NW Ontario, Canada
    Ja, your bladder is shot. Degree of difficulty depends on how it's plumbed.
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    Before you purchase a new tank I'd recommend that you consider installing a Pside-Kick http://www.cyclestopvalves.com/pdf/p...k-brochure.pdf. It's a Cycle Stop Valve with a small Wel-X-Trol tank (all that is required when using a cycle stop valve). A cycle stop valve will keep your pump from cycling and give you city like pressure. Call them and they will recommend a supplier in your area. It's simple to easy to install.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Aug 2011
    WI
    THis looks like a constant pressure system. I believe that is what I already have.
    Either way, do people recommend the Wel-X-Trol brand over all others?
    Jan 2008
    Virginia Beach, VA
    Not all, but I do!
    Porky Cutter, MGWC
  1. Well-trol pressure tank wx 202 operating pressure question
    By tlpayne in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-04-2010, 03:02 AM
  2. Water Pressure Issue with Well Trol WX 202
    By rgardeck in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-14-2010, 03:54 PM
  3. Kohler K-4519 tank cracked: looking for replacement and color confirmation
    By alistaircookie in forum Toilet Forum discussions
    Last Post: 03-16-2010, 06:58 PM
  4. Well-X-Trol tank capacity question
    By paullyboy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-18-2008, 09:29 AM
  5. Well X Trol Tank Question
    By GLH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-07-2007, 06:48 AM
