Results 1 to 3 of 3
Thread: Blower not turning off
    DIY Senior Member jerome8283's Avatar
    Oct 2006
    New York
    Default Blower not turning off
    Got up this morning and my central air blower was running but the compressor was off. It seems to be switch related because the compressor did come back on after the temperature rose. Usually when I turn off the air from the thermostat the compressor and blow turn off. Now the compressor turns off only. What could be the problem?
    Oct 2006
    New York
    Fan setting was not set to auto! Problem solved!
    Feb 2011
    NW Ontario, Canada
    An easy fix and one you'd kick yourself for if calling out a tech.
    My wife called out a tech for an intermittent furnace problem where it would run for less than a minute and shutoff. The tech tore the furnace apart before realizing the problem. Turns out the wife tossed a blanket on top of the garbage cans that where right below the fresh air intake for the furnace. The wind was blowing up a flap of blanket that would sometimes block the intake. DOH!
  1. Snow Blower
    By Gary Swart in forum Lawn Care/Landscaping
    Last Post: 12-22-2010, 08:04 PM
  2. York Indoor Air Blower
    By Vince B in forum HVAC Heating & Cooling
    Last Post: 11-23-2009, 07:47 AM
  3. Why would the blower keep running?
    By parineetha in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-27-2009, 11:55 PM
  4. AC blower starting capacitor
    By Bobver in forum HVAC Heating & Cooling
    Last Post: 06-30-2009, 11:19 AM
  5. Air tub blower placement
    By dlr77057 in forum Shower & bathtub Forum & Blog
    Last Post: 09-26-2006, 10:09 PM
