Results 1 to 10 of 10
Thread: Rough Cost Estimate: Basement Wet Bar and Bathroom Work
    DIY Junior Member bucky's Avatar
    Feb 2011
    Minnesota
    Default Rough Cost Estimate: Basement Wet Bar and Bathroom Work
    Gutted my basement (Minneapolis/St. Paul) and now in the process of building it out. Definitely building a bar, but not sure if I'll recoup enough money on adding a sink to make it worth while. Upstairs bathroom is overhead so supply lines (galvanized) are right there along with the drain line. Hard to say what the easiest route would be to tie in the venting. I'm told ventless pumps don't pass around here (Minneapolis/St. Paul) so busting up the floor seems to be the only option to drain the sink.
    Across the way is this lovely unvented bathroom. (I've got a one story and there's a closet above so running a new vent up through the roof would be relatively easy). The goal would be to make it a legal bathroom or in other words start over from scratch. I can do the drywall and carpentry and really just need the plumbing expertise to tie everything together so it is code compliant.
Size:  48.7 KBName:  Picture 007.jpg
    Yakima WA
    Bucky, I think you will find that the pros on this forum will very reluctant to even venture a rough guess. Local labor costs and unforeseen difficulties and problems make this virtually impossible. It's somewhat like saying my car has a noise in the engine, what will it cost to fix it. Best bet is to get local contractors to give estimates.
    Feb 2011
    Minnesota
    I've got the PM at a local company drawing up an estimate. I know there's variations nationally that would result in an apples to oranges comparison, but figured someone on here has probably done similar projects and could offer a ballpark, +/- a few thousands dollars. It's not like I'm going to take what someone says on here back to the PM. Mostly just concerned about the wet bar at this juncture.
    Nov 2010
    Maine
    I'll ball park it at 11 grand give or take
    quote; really just need the plumbing expertise to tie everything together so it is code compliant.
    The place to get that is from a LOCAL plumber, NOT a "PM" at a lumber yard.
    Nov 2010
    Maine
    How about the guy in the orange or blue smock ?
    Yakima WA
    But, don't call the guy that installed the slanted basin with the S trap.
    quote; don't call the guy that installed the slanted basin with the S trap
    Picky, picky. He did tell the homeowner it was NOT vented, and he did use a drainage 90, instead of a galvanized one.
    Feb 2011
    NW Ontario, Canada
    So, what's a PM? Prime Minister? Product Manager? Personal Masseuse?
    Maybe Project Manager and he is taking time off from constructing a half mile high building to figure this out.
  1. Plumbing rough in cost estimate
    By pediwent in forum Plumbing Forum Discussion & Blog
    Last Post: 12-09-2009, 06:30 AM
  2. Rough estimate of the cost to switch from gas to electric
    By chubyball in forum Tankless Water Heater Forum
    Last Post: 06-10-2009, 12:46 PM
  3. Cost Estimate for Bathroom Rough-in
    By spetrucco in forum Remodel Forum & Blog
    Last Post: 07-09-2007, 09:25 AM
  4. Need help for estimate cost
    By norvi in forum Toilet Forum discussions
    Last Post: 04-22-2006, 07:20 AM
  5. Rough - In Bathroom in Basement (cost)
    By Marty B. in forum Plumbing Forum Discussion & Blog
    Last Post: 03-08-2005, 12:31 PM
