Results 1 to 4 of 4
Thread: Water Pump ( Deep Well) runs continously
    DIY Junior Member BPRO's Avatar
    Aug 2011
    Ottawa Ontario
    Default Water Pump ( Deep Well) runs continously
    I have a challenge with a Water Pump that wants to run continuously.
    Pressure never gets to the cut off point.
    Tank seems to be OK however, I will have to check if pressure holds as it was very low ( 15psi).
    Any other suggestions from you folks?
    I also suspect that my pump may be somewhat worn down so I may have to repair or replace.
    Any suggestions appreciated.
    Thanks,
    BPRO
    Aug 2011
    Ottawa Ontario
    OK I checked the pressure again in the tank and it has dropped from 38psi where I set it at to about 19psi.
    Tanks should not loose the pressure this quickly is that correct? If so that would indicate we have a leak in the diaphragm. I have a Well-Trol WX 202. I guess I should replace the tank./
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by BPRO View Post
    Does the pressure drop when you shut off the pump and are not using water?
    Is the pump a submersible or deep well jet?
    How deep is the well?
    How high is the water table?
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    It sounds to me like you have a jet pump (above ground pump)! If this is the case, I suspect that the nozzle in the venturi (jet assembly) is plugged. Remove the jet assembly and remove any debris from the 1/4" nozzle and reassemble. You should have pressure now. Jet pumps don't build pressure the jet assembly builds the pressure!
    If it's a submersible pump (in the well pump) you have another problem!
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Deep Well Pump Runs Continuously
    By Blue Ribbon in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-27-2011, 07:14 AM
  2. Submersible pump running continously
    By may in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2010, 09:54 AM
  3. Deep Well Pump Runs 1 Cycle then cuts off.
    By Roger Horn in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-18-2010, 01:02 PM
  4. Deep well jet pump - runs a long time
    By av8or10 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-13-2008, 02:22 PM
  5. Continously running submersible pump
    By boze62 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-01-2008, 04:52 PM
