Results 1 to 5 of 5
Thread: Replacing water heater
    DIY Junior Member cag9228's Avatar
    Jul 2008
    Texas
    Default Replacing water heater
    All,
    I am replacing a water heater that developed a slight leak at the cold inlet. At first I thought it was the nipple, but after disassembling and reassembling the connections (used Rectorseal #5 on the threaded connections) I realized it was a leak on a weld.
    So when installing the new one, do they come with the T&P already installed? If so, do I need to remove it, dope it, and screw it back in? Ditto with the nipples. And should I be worried about over tightening threaded connections?
    Regards,
    Andy
    Most new water heaters that I'm installing have the T&P and the nipples preinstalled.
    Jul 2008
    Texas
    Ah ok. So then I just leave them alone.
    I'll attach the dielectric unions to the nipples and run copper from the unions up. That's pretty easy.
    Depending on the one you buy, the nipples may already BE a dielectric union...no reason to add another one. Also, depending on where you live, some places REQUIRE the connection to be made with a flexible supply, and some PROHIBIT it. It's much easier to screw the flexible copper supply pipe in rather than try to align it with hard copper, but either can work, depending on what your inspector wants.
    Jul 2008
    Texas
    Yeah the flexible connectors are out as an option due to code. Aligning the copper isn't that big of a deal.
  1. Need help with replacing my water heater
    By gaucho100 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-14-2008, 11:42 AM
  2. Replacing water heater anode rods?
    By Billy_Bob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-28-2008, 12:05 PM
  3. Replacing hot water heater
    By westmorelands in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-22-2007, 02:36 AM
  4. Replacing an Indirect Water Heater
    By phainley in forum HVAC Heating & Cooling
    Last Post: 04-08-2007, 10:05 AM
  5. Replacing old-style PEX, from water heater to bathroom
    By nelsonCounty in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2007, 11:11 AM
