Thread: Drywall or greenboard above shower stall?
    Default Drywall or greenboard above shower stall?
    I just finished installing a 4-piece fiberglass tub and shower surround. Should I use greenboard or regular drywall (or something else) on the walls above the shower?
    Jul 2009
    North Vancouver, BC
    Are the walls and ceiling going to receive tile or just paint.
    Green drywall is junk in my opinion and no worth any premium over regular drywall. Invest in a good primer (Zissner Cover Stain) and excellent bathroom paint if you are going that route. Drywalling ceilings you should work with a ceiling drywall or 12" center joists.
    If your setting tile on those walls 1/2" cement board or 1/2" hardie work great - so does Green EBoard. Green EBoard is not green drywall.
    Good Luck
    JW
    Just paint - and I will take your advice on using quality paint and primer. Thanks.
  1. Bifold Shower Door For Stall Sized Shower 40.25" Wide
    By turbocruiser in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2011, 04:57 AM
  2. Convert Slab Shower Stall to Level Floor for Steam Shower Unit
    By Saitek in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2010, 02:09 PM
  3. Repairing old greenboard and drywall shower wall
    By MikeinLV in forum Shower & bathtub Forum & Blog
    Last Post: 01-21-2010, 07:54 PM
  4. Shower stall
    By vinci in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2006, 04:54 PM
  5. Turning walkin shower stall into bathtub/shower combo
    By Brian_Houston in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2005, 05:13 PM
