Results 1 to 10 of 10
Thread: Toilet to fit under 30 inch banjo countertop..
    DIY Member JeffH's Avatar
    May 2006
    California
    Default Toilet to fit under 30 inch banjo countertop..
    Hey folks,
    Is the Toto supreme my only choice here?
    1) Must fit under 30 inch banjo countertop.
    2) ADA height seat.
    3) Like to stay away from Kohler "lowboy" type toilets if possible
    Thanks in advance!
    You should check out the Toto Ultramax ADA. It is 29-1/4" high. Another choice would be the Toto Supreme ADA. It is only 25-1/2" high. Both of these measure 16-1/2" from the floor to the top of the bowl.
    Supreme II, MS634164CEFG, 26" to top of tank
    Supreme ADA MS864114L, 25.5" to top of tank
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Go with the supreme or remove the banjo. Its nice having room if you need to change out parts in a few years.
    Plumber jimbo's Avatar
    Banjo countertops were a bad idea from the git-go. But if you must stay with it, your toilet choices are limited, and if you want ADA bowl, I think that rules out any two piece toilets. That would require a total tank height including the lid and the tank to bowl gasket space, of under 13" .
    May 2006
    California
    Default Much Thank!
    I figured that the Supreme would be my best bet. Thanks for the input.
    quote; if you want ADA bowl, I think that rules out any two piece toilets.
    Interesting comment, since the ONLY ADA toilets I have seen WERE two piece ones.
    hj,
    That may be true for you and your customers, but I sell and install lot's of one-piece ADA toilets.
    Most of my one-piece toilets that I sell meet the ADA requirements.
    Most of the older people are the ones with more money and they don't need to skimp on themselves.
    I don't have "cheap" customers, but I cannot remember EVER installing a one piece ADA toilet.
    Too bad.
    I install them all the time.
    This won't fit under a banjo top, but it's pretty nice.
    MS604114CEFG
  1. Changing 14 inch to 12 inch toilet
    By keano016 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2010, 08:11 AM
  2. Adapting a 9 inch Rough In to 10 inch Toilet
    By Noddaplumber in forum Toilet Forum discussions
    Last Post: 11-14-2008, 10:18 AM
  3. Cable tool or bore drill? 5 inch pvc or 4 inch steel?
    By Barnes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-16-2008, 05:48 AM
  4. Banjo counter/height above toilet tank
    By loke in forum Toilet Forum discussions
    Last Post: 03-19-2008, 06:30 AM
  5. banjo counter top over toilet
    By susiej in forum Toilet Forum discussions
    Last Post: 07-07-2006, 09:31 PM
