Results 1 to 2 of 2
Thread: brumby pump from Australia
    DIY Junior Member tomalidav's Avatar
    Aug 2011
    SE AZ
    Question brumby pump from Australia
    Has anyone ever heard or used the Brumby pump from Australia? It works on air pressure.
    DIY Member gritres's Avatar
    Jun 2011
    nw florida
    the brumby pump is nothing special, it's just an air lift aka pulsar pump where air bubbles lift water. you can make your own, it's kind of dumb to buy something so simple unless its cheap and i dont think brumby's are. they are great for clearing wells full of debris because there are no moving parts to get clogged. they are only efficient if they are submerged far under the water level. you want a 1:1 ratio at least, ie X feet of submersion under the water level for X feet of water level, but efficiency increases the more it is submerged. the problem is you have a bunch of air in the line too so it's only good for pumping water to non pressurized container like a trough for feeding your animals.
  1. locating back up sump pump in brackish water, minimizing rusting of pump
    By philip o'dowd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-16-2011, 11:05 PM
  2. Replies: 3
    Last Post: 01-03-2011, 01:29 PM
  3. How do I know if my water powerd sump pump is running and not the primary pump?
    By milkmoney11 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-12-2010, 07:30 AM
  4. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Solar and Geothermal Water Heating Forum
    Last Post: 04-20-2009, 09:33 AM
  5. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-21-2007, 04:49 PM
