Thread: What kind of pump
    DIY Junior Member tomalidav's Avatar
    Aug 2011
    SE AZ
    Question What kind of pump
    Just had a new well dug in SE AZ. 410 feet deep. Am completely off grid but do not want another solar pump. is there a 110v pump which could handle this? If not, I will use my portable generator to pump as we do not have 220v on our system.
    Feb 2011
    NW Ontario, Canada
    You don't say what the water table comes up to. It is a very important factor in choosing the right size of pump. This is just a generalization but I doubt a genset that only produces 110V would drive a suitably sized pump to draw from 400 feet. Rather than search for a 110V pump, you should consider a 240V genset.
    Aug 2011
    SE AZ
    Head is only 50' so i will be going w/the 240 thanks
    Dec 2009
    northfork, california
    My solar friend built a little oil field type pumper, and uses a standard pump cylinder and sucker rod to operate. I think its 600' and uses a tiny motor off of one dedicated panel. These last almost forever and all repairs are fairly easy from the surface.
  1. What kind of PVC fitting is this?
    By stealth71 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-01-2008, 05:32 PM
  2. What kind of tubing
    By Barry J in forum Irrigation / Sprinkler Forum
    Last Post: 04-23-2008, 12:08 PM
  3. What kind of tubing
    By Barry J in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-20-2008, 12:24 PM
  4. What kind of pump
    By Handywomen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-19-2008, 07:56 PM
  5. What kind of pump????
    By dave1941 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-30-2007, 07:32 AM
