Results 1 to 5 of 5
Thread: Any toilets with only a 26" depth on a 14" rough?
    DIY Junior Member badwife's Avatar
    Aug 2011
    Minneapolis
    Unhappy Any toilets with only a 26" depth on a 14" rough?
    I decided to surprise my husband with a bathroom remodel while he was out of town. He came home to find a bathroom with no sink and no toilet. Apparently I destroyed the only toilet in the world that fit the space. We have a 14" rough and the small space allows for only a 26" depth from the wall. I have spent hours on-line trying to find a toilet with no success - even the Totos do not have the short depth we require. Additionally, my husband insists the adapters that would allow the use of a 12" rough in do not work well. Does anybody know of any options?!?
    Do you have access to beneath the floor? Is there something in the way that prevented them from originally using a standard 12" rough-in? If the restriction is a door, would it be possible to rework that doorway to be a pocket door or an outside surface door (similar to a barn door)? Either of those can work well, and makes a small room much more manageable. 26" is short for any toilet, and then when you throw in the 14" rough-in, you've got even more problems. There are some offset flanges that work, but the more common one does not work well at all. But, if you have room to use one of them, you usually can move the whole thing to where it needs to be in the first place.
    The Toto toilets with the 14" Unfit work well.
    What your husband means, is that an "offset" flange doesn't work as well.
    For an offset flange to be installed, would mean redoing the drain.
    If a drain is redone, then often you can install it at 12". Not always. Sometimes there was a reason for the 14" rough.
    We do install and sell hundreds of the Unifit equipped Toto toilets; most at the standard 12", but also many at 10" and 14"
    They work very well.
    Here is your husbands options.
    He can pick up a 12" bowl.
    Then his next option is either a slim tank or a fat tank. Either way, the 12" bowl sets out in the room.
    Or you can pick up a Toto with Unifit, maybe a Vespin, and install it with a 14" Unifit to pull it back 2".
    Either way, you will never see 26" again. That toilet was made 90 years ago.
    The Unifit works very well at moving the bowl. Performance is very good too.
    Here is a Vespin installed with the 14" adpapter in an old Seattle home from the 1920's.
    Vespin
    Vespin II HET
    Carlyle
    Carlyle II HET
    Carrollton
    Carolina
    Carolina II HET
    Lloyd
    Pacifica
    Soiree
    Guinevere
    When I bought my home many years ago, the bathroom door opened in toward the toilet. I found this to be unacceptable, so I converted the door to a pocket door. That has proven to be a real winner. When I constructed a new small bathroom in my basement, I used a pocket door there as well. A swinging door eats up a lot of space in a small room. I concur with Terry's point regarding using one of the Toto's that use the Unifit adapter. Toto is the only company that makes this type of adapter, all models are excellent performers.
    Vespin
    Vespin II HET
    Carlyle
    Carlyle II HET
    Carrollton
    Carolina
    Carolina II HET
    Lloyd
    Pacifica
    Soiree
    Guinevere
    When your old toilet was made, they produced a special bowl with a standard tank for a 14" rough. NOW they use a special tank and a standard bowl which means it WILL project 2" further into the room than the old one.
  1. Best 14" rough in toilets
    By tfgal in forum Toilet Forum discussions
    Last Post: 07-27-2009, 04:01 PM
  2. Rough in for replacement toilets
    By Lolly in forum Toilet Forum discussions
    Last Post: 10-02-2008, 01:24 PM
  3. Recommendations: short depth and 10" rough-in
    By ling13323 in forum Toilet Forum discussions
    Last Post: 07-09-2008, 02:57 PM
  4. Thoughts about Niagara Conservations toilets and 10" Rough In Toilets
    By wanderin in forum Toilet Forum discussions
    Last Post: 06-02-2008, 05:35 PM
  5. Depth of poly? Depth of drip line?
    By ToolsRMe in forum Irrigation / Sprinkler Forum
    Last Post: 07-02-2007, 07:34 AM
