Results 1 to 4 of 4
Thread: Moen Posi-Temp 1222B Shower Cartridge
    DIY Junior Member SteveMar's Avatar
    Aug 2009
    Maryland
    Default Moen Posi-Temp 1222B Shower Cartridge
    In March 2011, we had our bathroom remodeled, and our new Moen shower fixture takes the 1222B cartridge. I know this because it leaked and I replaced it twice in the first month. I thought the third try would work out, but after four months the cartridge has again begun leaking and the tub spout is again dripping. I am sort of disgusted with this product, and am tired of replacing this over and over. I am using Moen parts, not aftermarket. My questions are--have others run into this sort of performance problem, and is there a better replacement product available than the 1222B? Thanks!
    It's possible that there is a scratch in the body, and no cartridge is going to last long. Have you talked to Moen? In most cases, they'll send you a free cartridge.
    Aug 2009
    Maryland
    Jim
    Moen has sent me a couple free cartridges, and will probably send me another one in this instance. Free cartridge aside, it seems like a cartridge should be able to function correctly for more than 1-4 months.
    As mentioned, if there is a scratch in the body of the valve that the cartridge fits into, that can abraid the seals and they won't last long. The only fix on that is to replace the body and the cartridge. Make sure that if there isn't any silicon plumber's grease on the cartridge, you put some on before inserting the new one. This will make it both easier to insert and help it last a little longer.
  1. Moen Posi-Temp....almost but not quite
    By das108 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2011, 03:37 PM
  2. Brand new Moen Posi-Temp Tub & Shower Valve, Model 2300:
    By oldberkeley in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-07-2010, 10:54 AM
  3. Moen posi-temp shower valve
    By Basement_Lurker in forum Shower & bathtub Forum & Blog
    Last Post: 07-12-2007, 02:06 PM
  4. replaced Moen cartridge 1222B posi-temp, now temps all wrong
    By CluelessinCanada in forum Shower & bathtub Forum & Blog
    Last Post: 03-25-2007, 08:33 PM
  5. leaky moen posi temp shower valve fittings
    By billonion in forum Shower & bathtub Forum & Blog
    Last Post: 02-16-2007, 09:02 AM
