Results 1 to 6 of 6
Thread: sealing of vent pipe at ceiling
    DIY Member ankhseeker's Avatar
    Oct 2013
    California
    Default sealing of vent pipe at ceiling
    I have a 6" vent from my over stove microwave that was installed by someone else. My wife noticed that there is cold air coming in the cabinet from the space between the vent pipe and the top of the cabinet. What should i seal this space with? Just insulation or is there a better product?
    Nov 2010
    Maine
    Silicone, spray foam, insulation, take your pick.
    Oct 2013
    California
    Thanks! I appreciate your recommendation.
    In the trades Dana's Avatar
    Jan 2009
    +1 on the expanding can-foam for sealing around the duct penetration.
    But seal the ducts too- they look as leaky as a sieve. Get rid of all that gummy backed "duct" tape, and seal the seams & joints with duct-mastic. Leaking warm moist air into a cooler damp space is a recipe for mold risk. Duct tape might be good for some things, but sealing ducts isn't one of them, name notwithstanding.
    Check and make sure there is a backdraft preventer in line with the exhaust duct too- the space could be cold simply from the convection of cool outdoor air down the pipe, displacing the more buoyant warmer air.
    Oct 2013
    California
    That duct passes through the attic and I can actually feel the cold breezy air coming through the opening. Great information. I will look into that duct-mastic stuff. Is that a paint on sealer? Thanks!
    Jan 2009
    Duct mastic is a pasty goop that you can apply with a putty knife or paintbrush- just be sure to apply it at least 1/8-1/4" thick or it can crack and lose seal. Box stores every where carry it in half-gallon tubs priced at about a sawbuck, or smaller amounts in caulk-gun tubes.
    If this is the only duct you need to seal you don't need much, but most houses have multiple places where it might be appropriate. It comes with different temperature/fire ratings, so pay attention to what you buy and where you apply it. (I went through a handful of the half-gallon tubs sealing the 90 year old heating ducts in my house, which made the ducts much quieter, and the air handler zone on the heating system more efficient.)
  1. Sealing around septic pipe
    By Geo422 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-11-2013, 11:08 PM
  2. sealing around dryer vent exit
    By maddfrog in forum Remodel Forum & Blog
    Last Post: 10-31-2006, 08:33 AM
  3. PVC Pipe Roof Vent Leak Onto Ceiling
    By DMD1991 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-31-2006, 06:46 AM
  4. sealing tub outlet pipe?
    By Kman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-19-2006, 07:02 AM
  5. Ceiling Leak from Condensation on Vent Pipe
    By cohughes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2005, 05:56 PM
