Results 1 to 1 of 1
Thread: Laundry Room Remodel Using Existing Vent
Threaded View
    DIY Junior Member nemesis's Avatar
    Aug 2011
    California
    Default Laundry Room Remodel Using Existing Vent
    I would like to re-model our existing laundry room (see attached drawing) with a clothes washer and sink, using the existing 2” vent if possible, so that I don’t have to cut additional holes in the roof. But I have several questions:
    1. Do I need to back vent at all (dashed lines in drawing) or can I simply run horizontally to the existing vent?
    2. Assuming that I do need the additional 1½” back venting, are the horizontal distances to the 2” vent too long?
    3. If the basic plan is ok, do I use san-T or combos where the 1½” vent lines intersect the horizontal drain lines?
    4. Washer drain must be 2”, but for the sink drain, can I use 1½” from the trap to the vertical? I have seen contradictory info on that.
    Any corrections or suggestions for a better way of doing it would be most appreciated.
  1. bad smell from laundry room and water heater tank room
    By ttaiko in forum Plumbing Forum Discussion & Blog
    Last Post: 01-11-2011, 01:07 PM
  2. Adding a laundry room, how to vent?
    By Guest in forum Plumbing Forum Discussion & Blog
    Last Post: 04-29-2008, 11:58 AM
  3. Laundry room remodel
    By alwaysremodeling in forum Plumbing Forum Discussion & Blog
    Last Post: 04-03-2006, 01:21 PM
  4. Laundry room remodel
    By alwaysremodeling in forum Remodel Forum & Blog
    Last Post: 04-02-2006, 08:26 PM
  5. Laundry room remodel. Moving pipes and need help.
    By Kevz in forum Plumbing Forum Discussion & Blog
    Last Post: 06-27-2005, 03:58 AM
