There are several things which can cause your problem, but they all boil down to one of two things. Either water CANNOT fill the cavity above the diaphragm to push it closed, or the water is leaking out of the upper chamber so it cannot build up pressure. FINDING the problem is the hard part because you have to make several tests to isolate what is happening AND WHY.
