Results 1 to 4 of 4
Thread: Water heater shutoff???
    DIY Junior Member moonapprentice's Avatar
    Aug 2011
    central wisconsin
    Default Water heater shutoff???
    my Gas water heater is starting to leak at the bottom of the tank base and is going to be replaced real soon. I am leaving my house for 1 week and am going to shut off the water heater inlet ball valve in case any thing happens while I am gone. I was wondering if It is necessary to shut off the burner as well or if I could keep that on.
    Aug 2009
    South*East
    Just set the thermostat on the heater to vacation. That will allow the pilot light to stay on . Then when you return home you won't have to relight it.
    John
    Depending where the leak is, and other conditions, the water could leak out of the tank while you are gone. Turn off the gas.
    Yakima WA
    Relighting the pilot light is not a very difficult thing to do. If the leak worsened while you were gone and the tank drained dry they could be serious problems if the heater kept trying to heat. Turn the gas off.
  1. Shutoff Valve in Hot Water Line of Water Heater
    By aaronm in forum Water Heater Forum, Tanks
    Last Post: 05-23-2011, 05:29 PM
  2. Replies: 5
    Last Post: 09-19-2010, 08:48 PM
  3. Shutoff Valve in Hot Water Line of Water Heater
    By aaronm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-22-2008, 07:38 AM
  4. repair leaky hot tub faucet by shutoff at heater?
    By serrow in forum Shower & bathtub Forum & Blog
    Last Post: 04-09-2007, 11:19 AM
  5. Remote sensor shutoff valve for water heater
    By lotuseclat79 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-09-2005, 12:50 PM
