Hi everyone. Quick and hopefully easy question.
We have a first floor laundry room and get occassional stankiness that I believe is coming from the washer. The washer drain pipe runs down through the wall into a crawlspace and then makes an 8ft. horizontal run where it joins a primary waste pipe (another 15-20 ft. horizontal run) that leads eventually out to the septic field. Both the horzontal run of the washer drain pipe and the primary waste pipe look to have a slight downward slope which I guess would be expected.
The problem (I think) is that there is NO TRAP on the washer drain pipe.
My question is three parts:
Should there be a trap?
If so, can I install it mid-way along the horizontal run of the washer drain pipe rather than at the bend where the vertical goes horizontal? (there is very limited working space in the crawlspace).
If the answer is yes, are there any guidlines on the dimensions of the trap - i.e., do I have to worry about staying above the level at which the main drain pipe goes out to the septic or any such thing?
Thanks very much in advance for any help!
