Results 1 to 3 of 3
Thread: Septic water pump issue
Hybrid View
    DIY Junior Member chunhuach's Avatar
    May 2011
    Washington
    Default Septic water pump issue
    The water pump in my septic system is not working well, two issues:
    1. Sometimes the float just won’t trigger the pump, even if I lifted it, do I need to replace it or should I look into something? Sometimes it will work (magically), should I replace it?
    If I replace do I just replace the head or I replace the wire as well? The one home depot is selling (http://www.*********.com/h_d1/N-5yc1...atalogId=10053) comes with the wire, that’s why I am asking. Replacing the wire is a little troublesome since the wire is buried
    2. Sometimes the float started to work (magically), but the pump will be triggered once a minute or so. The reason is that when the pump stops, water will back flow to fill the tank gradually. I am sure the drain field is still working as most of the water is pumped out, just a small amount of water will flow back every time. I don’t know if it has a one way check valve, should I install one? (I don't know why it wasn't installed originally so wondering if it's OK to install a one way check valve in a septic water pump)
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Yes you need a new float switch and they come with a new wire. There should be a check valve so if not then yes install one.
    May 2011
    Washington
    I took a picture:
    https://picasaweb.google.com/1151647...t=embedwebsite
    so should I just cut that PVC then intall a check valve? there isn't much room for me to work on without getting down to the tank. Are there flexible pipes I can use?
    The alarm also not working, if I know how to do it I would replace the whole thing with a panel which contains the alarm. I called a local company they will charge 239 for simple coming to see the issue...
  1. New Pump a year old still issue with dirt in water
    By watty770 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2011, 06:12 PM
  2. Jet pump to Fertilizer Injector-Pump Cycling Issue
    By orchidherder in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2010, 01:50 PM
  3. Replies: 34
    Last Post: 10-22-2008, 06:49 PM
  4. septic pump
    By motorboy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-27-2008, 05:43 PM
  5. Septic Design Issue
    By telleee in forum Plumbing Forum Discussion & Blog
    Last Post: 06-01-2005, 08:18 AM
