Results 1 to 6 of 6
Thread: Noise matters: Drake, Eco Drake, or Drake II?
    DIY Junior Member RandySea's Avatar
    Jul 2011
    Twisp, WA
    Default Noise matters: Drake, Eco Drake, or Drake II?
    I live in north central WA with no local place to try out toilets. My plumber says he'll install whatever I buy,. I had settled on the Drake then started considering 1.28 gals -the Drake II. I wondered if the dual jet would be noisier. Then I just saw here a reference to the Eco Drake.
    We'll be putting in two toilets. The guest WC isn't close to anything, so whichever flushes cleanest is a good choice, with 1.28 gal preferred. The other toilet is pretty close to the master BR. Quiet matters more there. But is there a noticeable difference among the three? This will be in new construction, so no old pipes or creaky floors.
    Thanks.
    They are pretty similar for noise.
    Plenty good enough for a master bath solution.
    I have a Toto Dartmouth in my master bath and a Toto Drake in the basement. Both are 1.6 gpf models. The actual flush process takes about 3 seconds. After that there is only a slight sound of the refill. Because low flow toilets release the entire flush water very quickly, there is bound to be some noise. Whether it is offensive depends on who is judging. Certainly it is no where near the noise a pressure assist toilet makes. Perhaps old time 5 and 7 gpf models were quite because the water was release very slowly (just my guess) In my opinion, none of the models you mention will make a great deal of noise. I'd go with the model that looks the best to you.
    Jul 2011
    Twisp, WA
    Thank you both for settling my noise concern.
    Randy
    Jul 2011
    Twisp, WA
    Well, it's a year later and I'm living in my new house. I am really pleased with the two Drake IIs I installed. They are indeed quiet, compared to any other toilet I've ever owned. They also refill fast, further keeping the noise to a minimum. Thanks for the advice, Terry.
    Also, as a big producer and therefore regular user of a plunger to clear my older, 1.6 gal toilets in Seattle, I am happy to report not a single plunger needed in 4 months. Ok, I did have two occasions where a second flush was necessary. Like I said, I'm a big producer. Nonetheless, this is still excellent performance.
    Apr 2012
    New York, NY
    Quote Originally Posted by RandySea View Post
    What a nice follow-up! I'm so glad to hear that a year later you are happy with your choice. I expect to be in the same place a year from now with our recently-installed Totos. We love them so far for all the reasons you mentioned. Hope you are enjoying the other aspects of your new home as well!!
  1. Toto Drake vs. Eco Drake & Unifit Adapter
    By jfwilliams in forum Toilet Forum discussions
    Last Post: 12-01-2013, 11:18 AM
  2. Toto Eco-Drake vs Drake II (E-Max vs Double Cyclone??)
    By justthinking in forum Toilet Forum discussions
    Last Post: 12-18-2010, 12:35 PM
  3. Toto Drake: 1.6GPF vs 1.28 GPF - Is 1.28GPF Drake just as good??
    By goshenplumber in forum Toilet Forum discussions
    Last Post: 08-09-2010, 10:53 PM
  4. Power Gravity (blue) Flapper in a Drake & Drake 2 (Gwyneth)
    By tyneskj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2009, 03:27 PM
  5. Flushing noise with Drake
    By AdamSmith1800 in forum Toilet Forum discussions
    Last Post: 08-16-2009, 01:01 PM
