Results 1 to 5 of 5
Thread: Well Water Black sediment in my Whole house water filter (YUK}
    DIY Junior Member JohnnyTuinals's Avatar
    Jul 2011
    Poconos
    Default Well Water Black sediment in my Whole house water filter (YUK}
    I live in the Poconos Pa. area and my house was built in 1996 (15 years}
    I thought it was best to replace my water heater and also my water Filter next to the water heater.
    Anyways
    The plumber showed me how bad the OLD water filter was,,It was eaten out the filter (Yuk}
    Lots of water Presure
    up till last year when I filled my jacuzzi it looked liked that the water was pretty cleaned
    Last winter the water was very dark and stuff flooting around (again Yuk}
    I never replaced the water filter in the 8 years I lived here.
    Anyways I replaced the filter a few days ago with a cheap $30 whilpool filter from lowes.
    Once installed
    after 15 mins of useing you would see BLACK sediment all over the filter but the water looks clean
    in a glass and the presure is good.
    I cleaned the Dirty black sediment filters a few times the First day and no change with a hose and still black sediment
    and the past 3 days I have cleaned and put the filters back in butttt still that same amount of black sediment.
    What do you good folks think might be the problem?
    To me since the Filter was eaten aways and I have been getting UNfiltered water for a long time,,,I
    would think its the well?
    What would you all do?....JT
    Jan 2008
    Virginia Beach, VA
    It sounds like a well problem. Filters stop debri and stuff from getting in your water system. I'd pump the water exaust (before the filter) for at least an hour to see if it clears up.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Jul 2011
    Poconos
    water exaust ,,,it that the Big Blue tank before the water filter?
    Or would it be best just to get someone in to just clean the line towards the filter?
    Makes no sense that a water filter would have all that black sediment within 15 - 30 mins.
    Would it be best to call a good local plumber or a Well guy,,,affraid many will rip me off lol........JT
    Jan 2008
    You need to have the water tested to see what is in it. It could be manganese or sand or plenty of other things.
    Until one knows what it is, there is no way to know for sure how to fix it.
    Jul 2011
    Poconos
    Thanks I will get the water tested on monday,,,,but for now I will
    just remove the filter and clean the Black sediment with a hose off of the
    filter....sediment just washs right off..................JT
  1. Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order?
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2011, 05:21 PM
  2. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
    By kstuart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2011, 02:04 PM
  3. Suggest whole house filter for sediment
    By brador in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-15-2008, 10:47 AM
  4. Which is best whole house sediment filter?
    By rosenb in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-15-2006, 07:50 PM
  5. Whole house sediment filter?
    By Vitaliy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-20-2005, 08:50 AM
