Thread: Replacing Plumbing System on Well
    Default Replacing Plumbing System on Well
    Hello All,
    It's been a while since I've been on here. I'm hoping I can get some assistance with a project. I bought a vacation home up north and I'm going to convert the hot water tank over to gas from electric. Simultaneously I'm going to move the hot water tank from the first floor down into the basement right next to where the water enters the basement. The expansion tank is very large and it's going to be replaced with a smaller bladder type unit and moved into the basement also. I'm also going to add a particulate filter, taste & odor filter and a water softener.
    I know a couple of things. One the water is hard. I had it measured there is no iron but there are 25 parts hardness. The scale I was shown when measured says that anything over 20 is very hard. The water tastes fine. I also know I have a submersible type pump. I don't know anything else. So if there is something I ought to know please advise and I'll figure it out.
    The link below is a diagram of the new system I'm looking to install sometime before winter. Please let me know if I'm missing anything here or if I should do anything differently. I tried to re-size the file but was unable to. That is why I provided the link.
    http://i213.photobucket.com/albums/c...bingDesign.jpg
    Tom
    Is there a reason I'm not getting any feedback on my question? Is it not clear?
    Tom
    Moderator valveman's Avatar
    Mar 2006
    I can't help you much with water quality. And I can't see your diagram very well. My questions would be; What kind of pump controller? Where is the pressure switch? You mean pressure tank not expansion tank?
  1. Replacing a Goulds J10S 1 hp pump for home sprinkler system
    By drainfly in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-07-2010, 07:21 PM
  2. Replacing an old water softener system
    By banthony4 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-23-2010, 03:04 PM
  3. Replacing plumbing to second story
    By MKB in forum Plumbing Forum Discussion & Blog
    Last Post: 10-02-2007, 02:15 PM
  4. Replacing Burnham 140,000 BTU Gas/Hotwater system
    By cpeters in forum Plumbing Forum Discussion & Blog
    Last Post: 02-04-2006, 09:23 AM
  5. Replacing composting toilets with low flush system
    By Jill in forum Toilet Forum discussions
    Last Post: 12-21-2004, 01:37 PM
