Thread: Soldering Taco Flo-Chek - Should Valve be Removed
    Default Soldering Taco Flo-Chek - Should Valve be Removed
    Do I need to tear apart the Taco 219 Flo-Check prior to soldering? I checked their web site but can't find installation instructions.
    Tahnks
    Default taco
    I believe it is all metal so it should not be necessary.
    alhurley
    Guest
    use MAPP or better to heat it quickly. flow the solder, let it cool enough to "set" then wrap a wet towel around the valve.
