From the way it is plumbed now, it looks like that vent line is the vent for fixtures below it. If so, you cannot use it as a drain. You should be able to cap one of them, and run the drain to the other (probably the one on the right), or run a new one down from that stud bay and vent it into the line coming up from below at 42" or 6" above the flood rim of the sink, whichever is higher.
