Thread: Pump cycling vs continuous operation
    DIY Junior Member OLDMAN's Avatar
    Jul 2011
    Michigan
    Default Pump cycling vs continuous operation
    I have a well and pressure tank. During the operation of my irrigation system, on the first two zones the pump runs continuously at 44 PSI. On the other three zones, the pump cycles on and off (30-50 PSI). Please advise me which is the preferable condition.
    You have a fabulous site! Found it on Google.
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    Constant operation is preferred
    Motor cycling is tough on the equipment
    Amperage draw is always higher on starting versus running so pump cycling could use more energy depending on cycle rates.
    If Payback is so important to you, why are you not driving a Toyota Corolla?
    Jul 2011
    Michigan
    Thanx 700, I shall replace the nozzles in the 3 zones which are cycling, with larger orifice nozzles; that should increase my volume and, hopefully, result in continuous operation of my pump.
    Jul 2011
    Michigan
    I replaced the nozzles in the 3 "problem" zones and, voila, I am now getting the desired continuous pump running full time in all zones. Again, thanx "zl700."
  1. Pump cycling vs continuous operation
    By OLDMAN in forum Irrigation / Sprinkler Forum
    Last Post: 07-28-2011, 08:17 AM
  2. Heat pump cold weather operation
    By John in herndon in forum HVAC Heating & Cooling
    Last Post: 02-06-2010, 06:56 AM
  3. Well Pump Switch - basic operation principles
    By bluinc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-29-2009, 11:08 PM
  4. Booster pump erratic operation-Help!
    By Raucina in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-03-2006, 10:05 AM
  5. Continuous pressure pump?
    By erupert in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-02-2006, 07:48 PM
