Thread: Toilet flow problem
    DIY Junior Member retzman22's Avatar
    Jul 2011
    Apex, NC
    Default Toilet flow problem
    First time homebuyer and just moved into this house. It has a well and septic. 1 toilet seems to flush and work fine. However the other toilet has issues. The tank seems to always be full of water but the bowl is pretty much empty. If you flush the toilet it fills with water rapidly but slowly drains out similar to a bath tub. Is the toilet clogged?
    I havent tried much due to being very new to the repairing toilet scene.
    Thank you very much,
    Ryan
    First make sure that the tube from the fill valve is pointed into the overflow tube.
    This is what refills the bowl.
    Another thing that can slowly drain a bowl is something like dental floss caught. It acts like a wick. The toilet could be defective, but the most common thing is as Terry mentioned, the refill tube not being positioned properly.
    DIY Junior Member oranges13's Avatar
    Jul 2011
    Michigan
    You stated it filled rapidly, but that it drained slowly.
    Does it swirl and flush normally and then cease to refill properly?
    In my experience, a clogged or slow moving toilet will fill, fail to flush well and then slowly empty - usually ending with lower than expected water level in the bowl.
    Check what everyone else has suggested but I'd attempt a good plunge or two as well.
  1. Flow Problem mystery with rear discharge toilet
    By FishAllThe Time in forum Toilet Forum discussions
    Last Post: 12-31-2009, 08:31 AM
  2. Flow problem
    By estone in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-06-2008, 08:18 AM
  3. Do I have a flow problem
    By designsoutdoors in forum Irrigation / Sprinkler Forum
    Last Post: 05-04-2008, 10:02 PM
  4. Seems to be a flow problem....
    By DIY in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2008, 07:20 AM
  5. Whole house flow problem
    By shag_fu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-25-2008, 07:01 PM
