Results 1 to 10 of 10
Thread: Splicing a Ground Wire
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Splicing a Ground Wire
    Hello,
    A ground wire was torn during excavation. Can this be spliced or does a new wire have to be run?
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Need some more information to give anything other than a general answer, but any wire that is broken is allowed to be repaired. How it is repaired depends on what kind of ground wire it is.
    By "ground wire" do you mean a "wire in the ground" or a "grounding" wire? There are few "single" ground wires which could, or would, be where an excavator could damage them, unless it was doing something like interconnecting power line towers, or poles.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    That is what I have been wondering about.
    Sep 2006
    cold new york
    It's a grounding wire (bare copper) that is run into the ground attached to grounding rods. It was torn by the excavator.
    Bill
    Gore Vidal.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    The conductor can be repaired, but, it must be repaired with an exothermic connection like a Cadweld or an irreversible crimp. It might be easier to just replace it from the panel to the first rod.
    Sep 2006
    cold new york
    How do I achieve an irreversible crimp? This sounds easier than a weld.
    Bill
    Gore Vidal.
    Jun 2007
    North Carolina
    Quote Originally Posted by molo View Post
    Bill
    The tool cost a lot of money
    Jusst replace the wire
    The ground wire should be so close to the building that he should have damaged the house at the same time. But, it should also be such a short route that replacing it would be easier than going to the trouble of locating a crimping tool and the splices.
    Aug 2009
    Maryland
    Here are some reasons replacing the wire is more economical.
    http://www.buycheapr.com/us/result.j...+crimping+tool
  1. Wire splicing question
    By charp in forum Electrical Forum discussion & Blog
    Last Post: 07-24-2011, 01:13 AM
  2. Need to add ground wire
    By rayh78 in forum Electrical Forum discussion & Blog
    Last Post: 11-03-2009, 04:03 PM
  3. Does a ground wire nut need to be in a box?
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 09-26-2009, 08:33 AM
  4. Ground wire
    By kregas in forum Electrical Forum discussion & Blog
    Last Post: 10-27-2008, 05:56 PM
  5. Ground Wire???
    By Fuoti in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-24-2008, 07:43 AM
