Results 1 to 8 of 8
Thread: Water heater making strange noise
    DIY Junior Member lnjohnson0685's Avatar
    Jul 2011
    GA
    Exclamation Water heater making strange noise
    2 weeks ago we had a thunderstorm which made me have to press the reset button on my hot water heater. Now it seems like every other day I have to reset it. Well the power went out again yesterday I just now reset it.I turned the breaker off so I wouldn't shock myself... and when I flipped the breaker back on it made a strange noise, it sounds like a current is running through the heater... like you can actually hear the electricity running through the wires. Should I be worried is it safe? The insulation felt alittle wet to me also.
    You had to press the reset button every other day, because the water was "super hot" due to one of the elements being shorted out. the sound you hear is probably that element "boiling water".
    Jul 2011
    GA
    so what should I do? I mean it sounds like electricity not boiling water. And should I turn down the temperature?
    DIY Junior Member supreme's Avatar
    Jul 2011
    miami,fl 33147
    Hi,what brand is your tankless water heater?
    Jul 2011
    GA
    it says STATE water heater-- Censible energy effiency the maintance guy is coming sometime tomorrow but thought i could fix it myself
    It needs at least one new element, and since it is electricity, you probably should NOT try to fix it yourself.
    Mar 2011
    Long Island, NY
    Quote Originally Posted by lnjohnson0685 View Post
    So what did the maintenance guy do yesterday?
    Jul 2011
    GA
    he hasn't showed up yet i will let you guys know if im here when he comes
  1. Water heater now making strange noises
    By miamicanes in forum Plumbing Forum Discussion & Blog
    Last Post: 12-06-2009, 10:59 AM
  2. Old Hot Water Pipe Making Noise (Why Now?)
    By glnow in forum Plumbing Forum Discussion & Blog
    Last Post: 03-19-2009, 01:22 PM
  3. Pipes making strange noise 24 hours a day
    By stocks in forum Plumbing Forum Discussion & Blog
    Last Post: 01-13-2009, 07:29 PM
  4. Toilet making strange noises after installing fill valve
    By mgfarmer in forum Toilet Forum discussions
    Last Post: 02-10-2007, 09:45 AM
  5. A water Pipe is making a knocking noise when...
    By Not-so-Handy-Andy in forum Plumbing Forum Discussion & Blog
    Last Post: 09-16-2006, 04:53 AM
