Results 1 to 13 of 13
Thread: 3 points of contact
    DIY Junior Member lauras2011's Avatar
    Jun 2011
    Needham, MA
    Default 3 points of contact
    I recently purchased a Toto Drake toilet and had it installed. The instructions say there should be "3 points of contact" between the tank and the back of the bowl (2 in front, 1 in back). But the rubber flange that goes over the large hole between tank and bowl is too thick ... so I can't get even one of the points of contact to really touch. I tried gently twisting the tank, rocking it, pushing down ... not sure what else to try. I don't want to crack anything by forcing it. There's a 1/8" gap for the two front points and about 3/8" for the one rear point ... That said, the toilet is all hooked up and working with no leaks ... but the tank does rock back/forth a bit. Is that ok or should I do something about it?
    Laura S
    I have NEVER had a tank which "rocked a bit" crack, but have had plenty which were in contact with the bowl break.
    If you carefully tighten the bolts evenly, a little bit on each side (say 1/2-turn of the wrench), you can get it closer. The gasket is designed to squish - as long as you don't try to tighten one side all the way before you start the other, you won't crack things. Little bit, side to side and you'll be fine. I like to slide a piece of paper or thin cardboard between the tank and bowl and stop when it starts to get tight, but I can still pull it out without tearing. A pro knows when to stop...the paper trick helps those of us that don't do it every day.
    Aug 2009
    Midwest
    Quote Originally Posted by lauras2011 View Post
    So a professional did the installation?
    That sounds like a rather wide gap, more like what American Standard buyers often report. When I installed my three EcoDrake I's, I didn't have as much trouble getting the 3 points of contact. I do recall that one of the tanks was a little tougher to snug than the others so I originally didn't take it all the way to contact. It rocked a little as a result, so I tightened it a bit more until it just made 3 point contact. No more rocking after that.
    Jun 2011
    Needham, MA
    It was installed by the guys who put in my new bathroom floor (not plumbers), so I wasn't too sure whether they knew a lot about toilets and Toto toilets in particular. They left a gap ... so I took off the tank and tried to do a better job myself ... but I couldn't get rid of the gap either. Based on the first person who replied (hj), I'm inclined to leave it alone ... I don't like the feeling of porcelain touching porcelain. I don't mind a little rocking ... it's better than chipping or breaking!
    Whether there is some movement or not, it hardly matters.
    It's just a little over thinking sometimes.
    Aug 2009
    Midwest
    Did you add tile to a bathroom where there was none before or to replace a thinner material? I ask this because it is a common mistake for non-plumbing contractors and homeowners to add tile to an existing floor and not also account for the new floor height around the toilet flange. What can happen is that the toilet flange ends up well below the floor surface and eventually the wax seal is unable to compensate. It will begin leaking...you might smell a sewer odor occasionally when this happens, see a stain on the floor, or you might eventually see water damage on the ceiling below if you have a lower level. There are spacer/adaptor rings made by Oatey and Sioux Chief to correct for this.
    I had this very problem in two baths in my home that were remodeled by contractors for the previous owner. One leaked on the ceiling below after about a year leading me to pull the toilet and identify the problem. The other didn't leak, but I suspected it had the same flange height issue. I confirmed this when I put in the new toilet, the old wax seal was just barely making contact all the way around. So I added a spacer.
    Jun 2011
    Needham, MA
    Yes! That is exactly what happened ... I'm not sure what they did about the additional height of the tile. They didn't account for it when re-installing the pedestal sink (I had to make the final adjustments and re-install the pedestal myself
    I'll get in touch with them and ask. Thanks for the advice!!
    Laura
    Last edited by lauras2011; 07-28-2011 at 04:43 AM. Reason: I needed to re-submit the post in order to "subscribe" so I'll get the notification emails ...
    quote; So I added a spacer
    That means you added an ADDITIONAL seam which could leak, if you did NOT install and seal the spacer properly.
    Jun 2011
    Needham, MA
    What's the alternative? If the wax seal won't work because of the extra hight of the tile, then how would you compensate for the extra space?
    Aug 2009
    Midwest
    I installed it properly and sealed per the instructions--ignoring the advice of the big box store "plumber" who said the sealant was not needed.
    They sell flange extender rings, but they have to be installed properly so they don't leak. ANother alternative is to use a waxless seal - Fluidmaster makes one. This uses an o-ring to make the seal, and a funnel fits down into the flange to direct the waste.
    Aug 2009
    Midwest
    Some use stacked wax seals. There are also some taller wax seals and ones with a stiffening ring in them that might handle the additional gap. The plumbers here can comment on what they like best in these situations and what has worked best for them. Personally, I would rather address the root problem by reducing the gap.
  1. Toto tank contact points question
    By I Play One On TV in forum Toilet Forum discussions
    Last Post: 10-06-2010, 03:08 PM
  2. Toto Drake, 3 Points of Contact?
    By JoelG in forum Toilet Forum discussions
    Last Post: 01-04-2009, 06:24 PM
  3. Driving Well Points
    By Wet_Boots in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-01-2007, 01:32 PM
  4. Who do I contact
    By LClan439 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-10-2006, 10:10 AM
  5. Cut-in / Cut-out points WAAAAY apart
    By bally in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-09-2006, 01:08 PM
