Results 1 to 5 of 5
Thread: Water Softener settings
    DIY Junior Member OhioTurner's Avatar
    Jul 2011
    Default Water Softener settings
    Just bought an foreclosure that had sat empty for 2 years,needless to say I had alot of frozen stuff.
    I replaced the softener with a 60,000grain that has a autotrol 255 valve/460i control it installed easily
    then I got to the programing, I set the time, my water has 30gpg of hardness and 2ppm iron with 4 residents so I set the hardness at 30 not sure thats right but its what I did, Capacity and salt dial,the manual gives no clear answers just says your dealer will set a time of install and if you have any
    questions contact your local dealer. Thats so helpful.....The plumbing store is great but they are just
    sales people with no field experience. Seems like there should be some sort of formula to come up with the correct settings. Anybody ever set one up with autotrol controls?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    When setting up a softener on water that has iron, you want to raise the hardness 3 grains for every part of iron (some will say 4-5 grains per part of iron). So with 2 ppm iron, you would raise the hardness 6 gpg or to 36 in your case. I would also recommend the use of Iron Out. This will keep the resin clean. If not, the resin may get fouled by the iron.
    Just to let you know. The settings have absolutely NOTHING to do with the degree of soft water. They just determine WHEN the softener should regenerate. Set them too low and you will run out of soft water before a regeneration. Set them too high and it will regenerate too frequently even if it does NOT have to.
    Jul 2011
    Thanks for the replies!
    If the salt setting the key What does the capacity setting do?
    I don't like having stuff in my house I don't fully understand..LoL
    Nov 2010
    Ocala, Florida
    1 cubic foot of resin will yield 30,000 grain of removal using 15 lbs of salt. If you use only 6 lbs of salt, you get 20,000 grains. So you get less salt useage with slightly less grain capacity. 60,000 grains with 2 regens @ 30 lbs of salt or 60,000 grains with 3 regens @ 18 lbs of salt.
  1. Settings for our new Fleck 2510sxt 48,000 gr. softener w/ 1.5 cu' SST 60 resin
    By k8ie in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-08-2011, 08:12 PM
  2. Help w/ Cloudy Water after changing softner settings
    By ArayT in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-17-2011, 08:55 AM
  3. Aquastat settings with indirect water heater
    By paul m in forum Water Heater Forum, Tanks
    Last Post: 02-15-2010, 08:27 AM
  4. water boiler temperature settings and circulator
    By jsherk in forum HVAC Heating & Cooling
    Last Post: 12-10-2009, 01:03 PM
  5. Most efficient water temp settings on furnace
    By cara in forum HVAC Heating & Cooling
    Last Post: 12-02-2007, 04:17 AM
