Results 1 to 6 of 6
Thread: Sprinkler stuck in Zone 1. Won't turn off.
    DIY Junior Member jad0807's Avatar
    Dec 2008
    Texas
    Question Sprinkler stuck in Zone 1. Won't turn off.
    I have a 6 zone system. The valves are spread across the yard, not centralized. When I start the system, zone 1 turns on like normal, however it won't move on to zone 2. So, I turn the water off from the Shut Off valve a the street.
    I go back inside and turn the system off at the control box. I go back to the street and turn the water back on. Now water is trickling out of the sprinkler heads in zone 1 with the sprinkler system turned off.
    Any suggestions?
    Mar 2011
    Long Island, NY
    There may also be a problem with the timer as you wrote this, but it sounds like your main problem is the valve for zone 1 in my opinion, is sticking open.
    Dec 2008
    Texas
    Is it the cellanoid or the diaphragm? Or should I replace both? or the whole valve?
    irrigation tech. mike1059's Avatar
    Jun 2011
    Portland, OR
    the problem in zone 1 is the diaphragm. after replacing it you should be able to see if you have another problem with the controller.
    A more pressing problem is that if you have to turn off the water at the street, you must NOT have the required backflow preventer, since it would have TWO shutoffs and you could turn off either one to stop the flow from the sprinklers.
  1. Boiler doesn't turn on but zone valve opens
    By speeder in forum Boiler Forum
    Last Post: 10-24-2010, 07:40 AM
  2. Boiler not firing up for 2nd zone, only 1st zone
    By bjferri in forum HVAC Heating & Cooling
    Last Post: 11-04-2009, 03:50 PM
  3. RainBird zone will not turn off!
    By russrb in forum Irrigation / Sprinkler Forum
    Last Post: 05-16-2009, 08:08 PM
  4. Dual zone vs. Single zone?
    By zombieman in forum HVAC Heating & Cooling
    Last Post: 03-04-2009, 04:48 PM
  5. how far to turn sink, tub, or toilet shutoff valves to turn on water
    By ydelamater in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2007, 06:28 PM
