Thread: Caulk: Silicone,Polyseamseal, Hercules or Other?
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Caulk: Silicone,Polyseamseal, Hercules or Other?
    Tub surrounds, what is the best caulk for the gap between a plastic surround and the tub?
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Plumbing Contractor Will Rogers Plumbing's Avatar
    Oct 2010
    Moore, Ok
    You talking tile or cultured marble? Tile you will want to use color match caulking(it will be sanded like the grout) and for cultured marble (or any solid surround) you will want to use silicone.
    Moore, Oklahoma
    http://www.willrogersplumbing.com/
    Expert Plumber plumber2011's Avatar
    Jun 2011
    Boston, Massachusetts
    Hi Molo
    Liquid nails sells a specific TUB SURROUND CAULKING...see image. This will definitely be the best bet for plastic surround panels as you can be sure the caulking won't bleed through the plastic panel as some other caulking can. It should be available at any home depot or lowes store.
    In terms of the "GAP" between the tub and the plastic surround, I'd recommend 1 or 3 hour shower caulking by GE (see image)....fast drying and mildew resistant guaranteed for 10 years...also available at any home depot or lowes.
    Good luck!~
  1. GE Silicone, PolySeamSeal, or Polyurethane Caulk for Tub Surround?
    By molo in forum Shower & bathtub Forum & Blog
    Last Post: 08-26-2012, 08:36 AM
  2. Question about Polyseamseal or other caulk
    By Macman in forum Toilet Forum discussions
    Last Post: 04-19-2011, 06:09 AM
  3. Hercules Base Hit II V Hercules Bolier Fluid
    By invisible-man in forum HVAC Heating & Cooling
    Last Post: 08-27-2010, 04:17 AM
  4. Silicone caulk vs. latex caulk
    By midge in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2008, 06:28 PM
  5. How to be neat with Silicone Caulk?
    By Snowman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2007, 09:12 AM
