Thread: Shower Spa water flow problem
    DIY Junior Member romy's Avatar
    Jul 2011
    Kingston, ON
    Default Shower Spa water flow problem
    We have a Shower Spa with 5 jets, a Rain shower head and a handheld shower and a small spout. There are 4 control valves, so one for each feature.
    We have issues with the water flow.
    When we first turn on the spout (located closest to floor), there is relatively good waterflow for about 2 seconds, then it changes to a trickle.
    The body jets and the rain shower head have no flow at all, the handheld only gives a few drops of water.
    We build a new house and all other faucettes in the house work fine.
    We bought this unit from Costco and have no idea about the brandname.
    What do you suggest we can do?
    Has anyone heard of similiar problems?
    Thanks Romy
    The most common cause would be a loss of pressure in either the hot or cold lines, but we cannot tell what could cause it. A stuck balancing spool would stop either the hot OR cold, but not both.
    There could be something caught in the valve(s) that floats to block flow once you open it. It could be a glob of solder, dirt, a pebble, a flap of teflon tape, packing material, etc.
  1. Water Flow At Both Faucet & Shower Head
    By jerryb437 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2011, 10:04 AM
  2. Terrible water flow coming from new tub/shower set - HELP!!
    By virtualblues in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-03-2011, 05:29 AM
  3. Shower head flow restrictor blocks all flow??
    By K. in forum Shower & bathtub Forum & Blog
    Last Post: 09-07-2010, 09:25 PM
  4. shower faucet back flow problem?
    By mikeprause in forum Shower & bathtub Forum & Blog
    Last Post: 09-16-2008, 07:33 AM
  5. Low flow problem with hot water tap
    By Wanna Be in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2006, 05:29 PM
