Results 1 to 7 of 7
Thread: Bradford WhiteAnode Replacement
    Default Bradford WhiteAnode Replacement
    I have a Bradford white water heater that is about 18 years old. I have occasionally drained and am going to again. I thought I'd replace the anode this time. It has never been replaced. Is it worth it to do it now and am I asking for more trouble than it's worth?
    thanks
    At 18-years, you are beyond the norm for replacement of the whole thing. But, some do last a lot longer. Depends somewhat on luck of the draw and the quality of the water. If you have an impact wrench, you should be able to get the old rod out, a breaker bar may not do it. Then, depending on the available height above it, you may need to buy a segmented replacement rod rather than a solid one. It's a tossup now, as the old rod is probably used up, and any impact may open up additional opportunities for it to then start leaking. Depends on how lucky you feel.
    Draining helps by removing any debris and maintaining the heating and volume of hot water you can get from the tank, but probably doesn't do much to extend the useful life from leaking.
    Dec 2009
    northfork, california
    Impact wrench for sure and heres your anode place. [as long as the old one had something left on it]
    http://fierychill.com/catalogsearch/result/?q=anode
    Default Anode Where is it?
    Am looking at this heater and can't figure out where the anode is.Pictures I've seen show it accessible from the top which makes sense. The unit is one of those vented models with a fan on top.So do I have to take that off along with the accompanying wiring? It looks like this thing was made not to replace the anode
    Feb 2005
    Cool leave it alone
    anode rod is incorporated into the hot water line nipple going intot he power vented heater...
    I suggest you leave it alone,,, if you have gotten 18 years out of a power vent heater its best to leave
    sleeping dogs lie,
    Your heater is old enough that it should be located on top near the back, but after 18 years, your heater is well past the time when an anode rod would be needed.
    Quote Originally Posted by master plumber mark View Post
    sleeping dogs lie,
    Thanks will do.
  1. What model Gas Bradford White to use?
    By DL in forum Water Heater Forum, Tanks
    Last Post: 12-11-2010, 07:06 AM
  2. Bradford White or Rheem
    By MiniSoCold in forum Water Heater Forum, Tanks
    Last Post: 10-25-2010, 06:44 AM
  3. Bradford White GX1-55??
    By The Rich Dude in forum Water Heater Forum, Tanks
    Last Post: 02-09-2010, 12:22 PM
  4. Bradford white issue
    By Garydaplummer in forum Water Heater Forum, Tanks
    Last Post: 06-15-2009, 05:07 PM
  5. GE (Rheem) or Bradford White...
    By ssacrf in forum Water Heater Forum, Tanks
    Last Post: 04-09-2009, 02:53 PM
