Results 1 to 2 of 2
Thread: No prime, Myers Pump
    DIY Junior Member tyancey66's Avatar
    Jul 2011
    Catoosa Oklahoma
    Default No prime, Myers Pump
    I recently purchased a house with a well, it has a myers pump, I removed the pressure guage on and filled the pump with water, put the gauge back on loosely and turned the pump on, did nothing, the water in the pump went no where, ran for a minute or two with no results. Any ideas?
    Jan 2008
    Virginia Beach, VA
    It usually takes a while for the air to purge from the pump. Keep the pump full of water and let it run for about 5 minute and it should prime. Be sure that when priming through the guage hole that the pump is full of water!
    If it's an old system with an air volumn control the Air Volume control on the tank could be bad. If it has an AVC, plug the small line to the pump. If it primes then the AVC is bad.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Can a Myers deep well pump be used as a shallow well pump?
    By dave115 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-22-2013, 02:43 PM
  2. Pump Won't Prime or hold prime
    By PAmom1991 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-31-2011, 07:09 AM
  3. Pump lost prime - won't prime (long post)
    By BWFRJR in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-30-2010, 06:37 PM
  4. Old Myers Pump Behaviour
    By canadianguy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-16-2009, 07:33 PM
  5. Myers Pump Performance
    By jgbfl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-28-2007, 03:06 PM
