Results 1 to 11 of 11
Thread: Tub install
    Default Tub install
    I am remodeling a bathroom and have purchased a 32" tub to replace the green cast iron tub. I looked at install instructions and understand that I will need to put in mortar bed for the acrylic tub. Also I will have to install new shower controller and move everything over 1" and slightly higher. How much time do I need to plan for a project of this type. I am comfortable with sweating etc. I this something over my head?
    Plumber jimbo's Avatar
    two weekends should be enough. You didnt mention the full scope of your project, i.e. tile wall? etc.
    I am installing cement backer board and tile. Not woriied about that so much as the time needed to install the tub...set in place and plumb. Thanks
    for a professional
    plasterboard tiled wall removed around tub 1-2 hrs
    shut water off and remove existing cast iron tub and valve. 1 hr
    break for bs 1 hr--that was alot of work
    clean area and repair any wall or floor wood damage 1-2 hrs if necessary.
    Install acrylic tub leveling 1x2 at proper level and test installation of tub 1 hr
    remove old trap, cover large opening where trap is, mix up structo lite, pour and set tub. 2-3 hrs. make sure everything is LEVEL to the best of your ability.
    preplan your jobs for the next day and see if you are missing parts etc.
    good job well done. let the tub sit over night
    next day
    get to the supply house early and get your parts that you forgot about. 1 hr.
    set tub valve basic single anti scalding 1- 11/2 hrs
    install tripwaste assembly and connect to existing waste line with new trap. 1-2 hrs.
    another break for bs...1 hr
    test the tub by filling it all the way up so the overflow is covered 1/2 way with water. Check all joints before draining and also while draining. 1/2 hr.
    Set tub valve temperature to max. 104 degrees. 1/2 hr.
    next day
    install wonder(cement) board 3 hrs
    preplan tile work 1/2 hour
    tile tub area 3-4 hrs
    install soap dishes and other shelving 1-2 hrs
    next day
    grout 2 hours.
    that afternoon
    install trim for shower valve 1 hr
    install shower doors 2 hrs or shower curtains 1/2 hr
    hope this helps
    CO and Smoke detectors save lives. Know your limitations and when to get a PROFESSIONAL. Your life and others may depend on it. Volunteer to be a local Fireman or EMT and help your community.
    DIY Senior Member Cal's Avatar
    May 2005
    Northern Virginia
    Jeas , Jeff,,,,,,,
    Nice bs job !! Why you want to sugar coat it for that man ?
    How 'bout:
    - Catching forearm on unforseen nail , travel to Emergency room and get stiched up ,,,,,,,,,,, 18Hrs
    - Dropping piece of castiron tub while going downstairs,,, tub through landing area wall and repair,,,,,6Hrs
    - First time DIYer trying to figure out how to get a 60" tub into a 60" opening with a toilet or toilet supply line in the way. Then figuring how to hook up the waste line without cutting the living room ceiling.,,,5Hrs
    - Beer with buddies,,,,3-8 Hrs
    -Time spent saying, " Don't they make something that........" or ," Why doesn't someone make something that ......" 3.5Hrs
    May 2005
    Northern Virginia
    OOPS ....sorry i just saw " for a professional " . O.K.,,your right on the time thing,,,my bad
    Cal
    DIY Junior Member JEP's Avatar
    Ringwood, NJ
    I'm involved in a simalar project.
    Cal - So how do you "hook up the waste line without cutting the living room ceiling"?
    John
    I must be doing something right. I haven't cut my arm yet, although I did put some slivers from the tub into my leg while busting out the old tub and at least the tub is over my shop and I won't have to worry about the ceiling in the living room. Thanks for the hint on filling the tub to test. See, your comments were not all bs.
    May 2005
    Northern Virginia
    John,
    If you do not have an access panel behind waste and water wall and if you do not have an opening under the tub ( 1st floor ceiling) it is one of the works of art to hook up a new tub .
    Let's say you change a small piece of pipe and the trap over to PVC . The tub comes with a cut sheet to tell you exact measurements of the waste center and how high to place the bottom "shoe" and how high to place the overflow outlet. This ALL must be lined up perfectly and level for everything to come together,,,,,If it's right,,,when you set the tub in place you should be looking down into the threads of the bath shoe (approx.1/4" low to allow for washer ) and looking into the center of the overflow straight ahead ( approx 1/2" back from tub to allow for washer)
    It is very possable,,,,take your time,,measure,measure,measure!
    Ringwood, NJ
    Sounds doable. I'll give it a try. Thanks Cal
    John
    DIY Member
    Langhorne, PA
    I am on my 7th weekend! If you don't know exactly what is the right way to do things, and/or if your bath had serious problems from years of leaking, neglect, or was never built correctly in the first place...you could be in for the long haul.
    I started my bathroom project back in the end of september...I thought i would just tear down the old wallpaper, pull out the fiberglass tub, replace the tub, retile the floor and paint the walls, and then add a new vanity, sink, mirror and lights. WRONG!
    Every time I removed something or tried to install a new fixture, I found more problems. At the end of the first weekend I decided everything had to be removed. The walls weren't plumb, there were five poorly repaired holes in the drywall, and the floor was a roller coaster, my new toilet wouldn't sit flat on the floor. The mice trashed the ceiling vent, the electrical wires running to and thru the bathroom were an electricians nightmare, yadda yadda yadda, etc, etc.
    Just be careful and don't get carried away if you are on a budget stick to it!
    A remodeled bathroom, can easily set you back 7000 bucks for just the materials and fixtures. Companies are charging 20,000 to 25000 dollars for a remodeled bath. It can be complicated to get everything working right. Good Luck.
