Thread: 1950s Crane Tub/Shower Problem
    DIY Junior Member deesworld's Avatar
    Jul 2011
    Baltimore, MD
    Default 1950s Crane Tub/Shower Problem
    When using the shower, just as much water comes out of the tub spout as the shower head. The hot and cold knobs also need some attention because when you open the faucet more less water comes out (its a science to get the correct temp) Should I start with the tub spout since that's where you turn on the shower head? Is this where I will find the "diverter" you all are talking about in other posts? Been waiting for my husband "to get around to it" but he doesn't use this shower so I may be waiting a looong time (we've been here for 15 years already).
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by deesworld View Post
    Been waiting for my husband "to get around to it" but he doesn't use this shower...
    Maybe you need to invite him to use it.
    If the tub spout has a pull up diverter built into it then yes, that would be a good place to start. If the diverter comes out from the wall, then leave the spout alone.
    As for the more is less faucets, do you have a brand and model or can you post a pic?
    If the diverter to activate the shower is on the tub spout, the best one generally available is one of these http://www.deltafaucet.com/search/re...rter+tub+spout . As you can see, they come in numerous finishes and styles. I installed one at my mother's and it works fine. The only thing is that when you shut the water off, the spring that retracts the pull-down is moderately strong, and it clunks. After the first time, you'll ignore it.
  1. Is a 1950s rough-in code compliant for a new bathroom?
    By Ian Gills in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2009, 05:54 AM
  2. Old Crane spout/ diverter problem
    By agabovich in forum Shower & bathtub Forum & Blog
    Last Post: 05-27-2007, 03:58 PM
  3. Crane Toilet - flushing problem
    By Nanette in forum Toilet Forum discussions
    Last Post: 08-28-2006, 05:44 PM
  4. 1950s home - copper type/diameter?
    By Redline in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-07-2006, 06:23 AM
  5. Problem with Crane Pressure-Assisted Toilet
    By BluesBrother in forum Toilet Forum discussions
    Last Post: 03-01-2005, 05:50 PM
