Results 1 to 6 of 6
Thread: $10K in damage so far...HELP NEEDED PLEASE!
    DIY Junior Member mizrachi's Avatar
    Sep 2010
    NYC
    Default $10K in damage so far...HELP NEEDED PLEASE!
    I live on the first floor of a four story 80 year old Brooklyn apartment building with (most of) the original 2 inch cast iron drain and vent pipes. Twice in the last three months and once two years prior an obstruction (or gunk buildup) has stopped up the kitchen drain line, somewhere between the second floor and the basement. This seems to happen when residents above the second floor use their dishwashers. The soapy water hits the obstruction or gunk-narrowed section of pipe and reverses flow back up the drain line and then out of the second floor sink and dishwasher. Twice now the water has filled the second floor sink and dishwasher, overflowing onto her floor and down to my ceiling causing significant damage.
    My first conclusion was that the obstruction must be between my floor and the floor above it, since waste water has not come up into my sink. However, it turns out that my kitchen, for whatever reason, is not connected to the kitchen drain line but the vent line. This means that the obstruction or built-up section(s) of pipe can be anywhere from the basement where it meets the sewage line to the second floor.
    A plumber noticed two 45 degree elbows connected to the drain pipe right above the basement ceiling. He thinks that this is a likely area of congestion. However, he can not be certain and says that even if he replaces this section of pipe the area prone to these obstructions could still be above it. It would be hard to tell visually and the pipe is too small for a camera.
    Since this has happened twice over the period of a few months we must find a solution. What should we do?
    Replacing the entire drain pipe from the second floor down would seem to be the most thorough course of action but it would entail major expense and inconvenience. Periodic snaking of the lines may lead to further damage. Bio-Clean in a multi-unit apartment building sounds tricky. Replacing only some of the pipe sounds like a gamble.
    What do you recommend? All help is greatly appreciated.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Flushing the line with a jetter is your best solution. This will return the pipe to close to original diameter by cleaning out the grease and soap build up.
    quote; for whatever reason, is not connected to the kitchen drain line but the vent line.
    Actually, in a multifloor situation, that is the most COMMON way to do it. But to be more precise, the vents for the upper floors are connected to the first floor's vent riser. One benefit is that your sink is out of the upper floor's "suds zone" which could cause a different type of backup even without a stoppage in the drain line.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    LIKE POSTED ABOVE GET THE LINE JETTED
    AND THEN USING A MINI-CAMERA BY TROJAN IT WILL FIT THOUGH 11/2 " & 2" DRAINS
    YOU CAN CAMERA LINE TO SEE WHAT PROBLEM IS !
    http://trojanworldwide.com/Trojan%20...20Systems.html
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    DIY Junior Member
    Nov 2011
    Philly
    They do have camera's that can go down 1 1/2" stacks.
    quote;
    A "multi story" drain stack would NOT be 1 1/2". Jetting would NOT remove rust and corrosion from a metal drain line.
  1. minimizing damage
    By remudagirl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-14-2010, 10:47 AM
  2. Fire damage
    By Bill Arden in forum Remodel Forum & Blog
    Last Post: 06-01-2009, 09:31 PM
  3. Help! How much damage did I do?
    By bradg in forum Shower & bathtub Forum & Blog
    Last Post: 12-23-2008, 05:33 AM
  4. structural damage?
    By Cookie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-25-2006, 06:46 AM
  5. Flood damage
    By jimbo in forum Plumbing Forum Discussion & Blog
    Last Post: 09-20-2005, 10:11 PM
