Results 1 to 7 of 7
Thread: Basement rough in - does this look OK?
    DIY Member export!'s Avatar
    Oct 2009
    Ontario, Canada
    Default Basement rough in - does this look OK?
    I'm hoping to keep this simple and I think the drawing has all the info. The 2" shower vent will continue out the roof and the 1-1/2" vents from the lav and laundry will tie together 5' up, and pick up the 2" above the ceiling. I couldn't find a long turn 90 for the closet bend fitting in the drawing but I will either use one or use two 45s.
    IANALP
    (I Am Not A Licensed Plumber)
    Nov 2010
    Maine
    It would fly under the IPC but many localaties still require a vent for the toilet line
    I would forget the "long turn 90, or two 45s" and use a hub 4x3 closet bend. It is the ONLY way I install my toilet riser pipes.
    Oct 2009
    Ontario, Canada
    Default Interesting
    Thanks very much for the input. I guess I'll have to run it by the inspector. I'm located in Ontario and I'm not sure what our code is. I guess it's close enough to not get laughed or yelled at!
    That 4x3 fitting is cool - I've never seen one of those before. I can see how well they would work but is that the only time in DWV plumbing you're allowed to in effect reduce the pipe size ??
    If I need to vent the closet, I would change the shower vent to 1-1/2 and vent the closet with 2" correct? At that point could I connect the other vents from the group and run to the roof with 2" ?
    IANALP
    Nov 2010
    Maine
    [QUOTE=export!;306728]That 4x3 fitting is cool - I've never seen one of those before. I can see how well they would work but is that the only time in DWV plumbing you're allowed to in effect reduce the pipe size ??
    It is the only place where the code allows the reduction.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    You are fine under the Canadian national code, the toilet is wet vented and is 2".
    Oct 2009
    Ontario, Canada
    Jerome - thank you very much - the inspector agrees! Good to go. He mentioned something about 5' being good. I imagine it's that the shower drain/wet vent connects to the 3" horizontal run within 5' of the toilet flange.
    Edit - from planning to completion!
    IANALP
  1. Basement rough in
    By daechuyl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2010, 03:40 PM
  2. Basement Rough In
    By cruiser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-10-2007, 05:31 PM
  3. Basement Rough-In
    By KenM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2006, 04:53 AM
  4. Basement Rough In
    By GURTSAK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2006, 04:44 AM
  5. Basement rough-in
    By BillyD in forum Remodel Forum & Blog
    Last Post: 03-07-2005, 02:27 PM
