Results 1 to 4 of 4
Thread: Is the Tub Steel or Cast Iron?
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Is the Tub Steel or Cast Iron?
    How can you tell?
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Tap it. A cast iron tub will sound a lot thicker than a steel one. A steel tub will "ring" like you were hitting a sauce pan.
    Sep 2006
    cold new york
    I tapped it and wasn't sure. I hit it with the sledge and it didn't break. I dropped it off of a third story deck and it broke. It was cast iron.
    Didn't hit it hard enough!
    Gore Vidal.
    Well, you did not say you had removed it, otherwise I would have told you that if YOU can lift it, it was steel. If it took two or more people to lift it, it was cast iron.
  1. cast iron fitting installed in cast iron soil pipe
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2009, 06:20 AM
  2. Cast iron vs galvanized steel.
    By duffers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2007, 01:18 PM
  3. Steel, Fiberglass or Cast/Tub Replacement Questions
    By joshjens in forum Shower & bathtub Forum & Blog
    Last Post: 03-27-2007, 05:58 AM
  4. Removing galvanized steel pipe from cast
    By jdkimes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-20-2006, 09:10 PM
  5. Steel Or Cast Iron?
    By BMWMK2 in forum Shower & bathtub Forum & Blog
    Last Post: 02-10-2006, 10:56 AM
