Results 1 to 6 of 6
Thread: AC thermostat ??
Hybrid View
    DIY Member rayh78's Avatar
    Sep 2008
    Virginia
    Default AC thermostat ??
    Have a rental property been working on that now vacant. Janitrol 2 ton heat pump about 6 years old.
    Noticed I would temp at 84 when I left at night. Following morning I get there and the actaul temp reads 77. Look like a cheap no name thermstat so replaced with a used Honeywell that worked good before. Had stored in my shed because switch to a programable one in my own home.
    This seemed to work fine for days. When there working during the day I turn down to about 77 and then back up when I leave to about 84. Then a few times found the place at 77 the next morning. According to the display and verified with a laser therm I have.
    Called my AC guy. He saids it has to be the termostat.
    So buy a new honeywell thermostat and install. A few days later its doing the same.
    Either something wrong my AC guy does not know about. Or at night when I leave its able to hold the 77 temp without the ac cutting on for 12 hours with the thermstat turned up to 84.
    It does seem to turn on and off like it should during the day when working there.
    Does this make any sense?
    thanks
    Feb 2011
    NW Ontario, Canada
    I don't know what overnight temps are like there but it is possible that it is simply holding the temp. You could of course disconnect the thermostat or flip off the breaker when you leave to see. Some smart theormostats will keep stats on usage so installing a smart stat could tell you if it's running at night. You could also leave some tissue paper on the air registers and see if the fan blows them off.
    Mar 2011
    Houston, TX
    If it is a smart thermostat.
    Once you set the temperature you have to hit the "Hold Temp" , or it will revert to "Run Program"
    Feb 2011
    NW Ontario, Canada
    I can see nothing in the OP that would suggest he has a smart programmable thermostat.
    Mar 2011
    Houston, TX
    I guess that I assumed it was.
    Sorry, Bad Me...
    Sep 2008
    Virginia
    Yes, just NON programable
  1. Thermostat
    By Giles in forum HVAC Heating & Cooling
    Last Post: 12-15-2010, 11:19 AM
  2. Is it my thermostat?
    By cpio in forum HVAC Heating & Cooling
    Last Post: 11-06-2009, 05:09 PM
  3. Thermostat Help
    By Jafo in forum Electrical Forum discussion & Blog
    Last Post: 11-01-2009, 04:29 PM
  4. Can I use one thermostat?
    By fazy in forum HVAC Heating & Cooling
    Last Post: 11-09-2008, 07:27 PM
  5. what's behind the thermostat??
    By ginahoy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2007, 04:46 AM
