Thread: Pressure switch will not turn on
    DIY Junior Member walkingscar's Avatar
    Jul 2011
    Salado, TX
    Default Pressure switch will not turn on
    Gentlemen:
    I cured part of my problem by resoldering the start cap back in the circuit board. The problem now is the pressure switch will not cycle. I can manually activate the switch and the relay in the control box turns on and the tank begins to fill. I can turn the water on and run the pressure in the tank down to 6 psi and the pressure switch will not turn on. Their is ac getting to the switch since the start relay works. I have replaced the pressure switch. I'm guessing, could the small pipe that the switch is connected to be clogged or maybe a clog somewhere else. I'm pretty much running out of places to look. I really need some help. I have 23 dogs and about 40 cats that depend on me for water and food. Any help would be appreciated.
    Walkingscar
    Feb 2011
    NW Ontario, Canada
    Yes, the pipe can plug up with minerals. Disconnect the pipe from the switch and see if water comes out.
    Jul 2011
    Salado, TX
    Yes the water comes out of the pipe.
    Feb 2011
    NW Ontario, Canada
    It is possible there was sand in the pipe and that sand migrated to the diaphragm on the switch. If you disconnect the pipe from the switch and the switch doesn't close, look for sand under the diaphragm. If the switch has a low pressure cutoff, it may be maladjusted and tripping the cutoff.
  1. Light Switch to turn on wall outlet
    By coopns in forum Electrical Forum discussion & Blog
    Last Post: 02-08-2010, 04:22 PM
  2. Super High pressure, but pressure switch appears to work properly
    By yergnov in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2009, 05:14 AM
  3. Replies: 1
    Last Post: 05-14-2008, 10:13 AM
  4. 2 Houses, 2 Pressure Tanks, 1 pump, 1 controller, 1 pressure switch pro help needed!
    By betaman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-05-2008, 05:07 AM
  5. Which way do I turn the pressure switch?
    By CrystalRose in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-18-2007, 11:40 AM
