Results 1 to 5 of 5
Thread: dry stack retaining wall in process
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default dry stack retaining wall in process
    I am building a 2.5' height (in total, 6" of the 2.5' will be burried, so only about 2' are above the ground), 75 feet long, 1 foot thick dry stack retaining wall now.
    I have done the footing and first course. The base and the first course are about 18" width. The base is about 4" crushed stone.
    please have a look to see is there anything is not good enough? do I have to fill in those holes with crushed stone after the first course?
    thanks,
    May 2011
    MA
    Another question is:
    if I want to keep adjacent stone level for next course to do 1 over 2 and then 2 over 1, I found it will make me build a relatively levelled course. Then I have to use the same or similar thickness stones. My wall is about 73' long. I am worry it will be hard to find similar thickness stone later. Should I always keep adjacent stone level? I know I can use very thick stone to change to a new thickness level but the final result is the same, I think.
    May 2011
    MA
    done few weeks ago;
    May 2011
    MA
    two more. We like it!!!!!!!!!!!111
    Software Engineer osx-addict's Avatar
    Jun 2006
    Los Angeles
    Yikes! That looks like a LOT of manual labor!! Looks great though! If I was reading correctly, you used no adhesive to hold things in place? Just curious..
  1. retaining wall
    By BenWara in forum Lawn Care/Landscaping
    Last Post: 04-15-2011, 11:01 PM
  2. The Aging Process
    By Cookie in forum Health and Wellness Forum
    Last Post: 02-10-2011, 05:55 AM
  3. Best finishing process for tub/shower inserts
    By abjosar in forum Shower & bathtub Forum & Blog
    Last Post: 08-11-2007, 10:48 PM
  4. Site membership process
    By Gouranga in forum Terry's Corner
    Last Post: 06-30-2006, 06:08 AM
  5. Leaky Basket Strainer/Frozen retaining nut
    By Verdeboy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-20-2006, 08:58 PM
